Technical Manual Transmission Flushing / Cleaning
Discussion in 'The Hokey Ass Message Board' started by HuskerNation, May 31, 2020.
  1. HuskerNation
    HuskerNation
    I pulled the plug on my stock 1937 Hudson transmission & initially it appeared pretty clean but then upon closer inspection I saw it wasn’t. So I’m wondering if anyone has a recommendation for flushing / cleaning out the trans before I put new gear oil back in her. So far she’s sat overnight with plugs out. Below are photo of drain pan from trans & the paper towel used to clean out the concave area of the two plugs:
  2. hemihotrod66
    hemihotrod66
    I don't know what year they stopped using a wet clutch in Hudsons....The clutch used a fluid called Hudsonite oil....Just some info for you....
  3. Someone else might chime in.
    what I’ve done in the past with dirty manual transmissions , diffs and transfer cases is just multiple oil changes to flush out sludge n gunk.
    mid everything else is working fine just change the fluid a few times.
    Find out what your unit takes IF it does take a unique fluid/ oil
  4. dirty old man
    dirty old man
    The Hudson clutch is what used the special fluid. I'm not sure, but I think the actual trans used a normal gear lube. I remember the clutch fluid came in a small, maybe 4-5 oz., can and all I ever saw was in the Permatex brand.
  5. HuskerNation
    HuskerNation
    The clutch is a completely different bird & indeed uses “Hudsonite” oil in the actual clutch unit. A few guys sell it that I know of but I’m working on the actual transmission, not the clutch. Most use a 75w-90 & must be “yellow metal safe” (brass, bronze, copper) so typical guys stay with GL4 just to be safe. I have seen a few GL5 gear oils that state they are yellow metal safe, like Royal Purple Max Gear.
    I actually have a couple of the old Permatex clutch fluid for the Hudson!
  6. Jmountainjr
    Jmountainjr
    If the trans uses a heavy weight gear oil I have used some diesel or kero as a flush.
    Truckdoctor Andy, Truck64 and pitman like this.
  7. squirrel
    Keep in mind that a flush will flush the crap into places that you might not want it to go. I would take the trans out, take it all apart, clean, inspect, reassemble with new gaskets, and add new GL5 oil because they have it at walmart.
    But I've been known to do stupid things, involving driving old cars.
  8. HuskerNation
    HuskerNation
    I opted to just toss in some Wally World gear oil I had & then run her since she’s up on jack stands. Got her plenty warm then drained her right after I shut her off. Color looked good so I’ll just add the gear oil I bought for her & go with it that way. If I do a clutch down the road I’ll pull the trans & can go through her then. Thank guys!
    dirty old man and squirrel like this.
  9. Wrench97
    Wrench97
    Epoxy a magnate to the top of the drain plug.
  10. 51504bat
    51504bat
    In the old 4 speed crash box in a '40 1 1/2 ton Ford I had I flushed it with diesel. Sold the truck a year or so after that so I can't say what the long lasting result was.
  11. lostone
    lostone
    from kansas
    Flushed with diesel too. Then a wand air blower in the hole blowing around then another flush with diesel and then oil and done.
  12. Ebbsspeed
    Ebbsspeed
    This would be cruel and unusual punishment, not to mention you'd likely never be able to re-install the drain plug.
    Desoto291Hemi, Happydaze and egads like this.
  13. Wrench97
    Wrench97
    Done it quite a few times on older trans.
  14. Ebbsspeed
    Ebbsspeed
    Uhh, I was taking advantage of your mis-spelling of the word.
    mag·nate
    /ˈmaɡˌnāt,ˈmaɡnət/
    noun
    1.
    a wealthy and influential person, especially in business.
    I usually epoxy or JB Weld a magnet in the drain plug on any vehicle I have.
    Desoto291Hemi and egads like this.
  15. nrgwizard
    nrgwizard
    from Minn. uSA
    Yah, I caught that right away. Funny... :D .
    Marcus...
