What is everyone using for manual transmissions in their model a's.I read Flat Ernies tech article on the T-5s. Great info I am having trouble locating a GOOD use one at an affordable price.I have a 63 muncie 4 speed does anyone know if someone makes a hydraulic slave cyl kit that would work with this trans? I will be running a 350 small block for the motor. Any info would be appreciated
A 37 LaSalle three speed in the model A sedan and an aluminum two speed in the A frame under the 27 coupe. Both are a nice fit.
www.wilwood.com has slave cylinders and pedal assemblies. If you go with an old dual master cylinder like the 61'-62' Chevy trucks or Internationals, you will have to have the clutch side sleeved down to 3/4" bore. www.brakecylinder.com
If that is a wide ratio, you're gonna love it. Set it up w/3.23 rear gears and fourth will be like an overdrive. As to hydraulic clutches, save your bucks, they don't always grip immediately, and if you wish to shift quickly, then you'll be turning back to a manual linkage!
Only if you have air in the line. Back when we still used a clutch in our race cars, we used the diaphragm type hydraulic throw out bearings with great success. Shifting quickly was never an issue. You have to be sure the thing is properly shimmed and that your system is properly bled. Slack in the system and air in the lines will lead to sluggish disengagement, but those things are all very preventable.
