Original early man-a-fre intake manifold for Chevy small block. American Graffiti 32 uses this intake. Only selling this because I have 2 and this was an extra I picked up for my car and dont need it now. Very nice, no corrosion, no cracks , no chips, no stripped holes.There are 2 threaded holes in the center ( 1 between the carbs on each end) and cant really be seen when the carbs are mounted, that I never found out what they are there for and they have been plugged with some kind of epoxy (see the pic) My other one has these also and there are pipe plugs in them. You can leave as is or drill out the epoxy and put the plugs in if you choose. Top few threads on the distributor hold down bolt hole look a little worn but wont affect in any bad way, just wanted to point that out. $1500 + shipping
