Technical Mallory Unilite in a Ford FE
Discussion in 'The Hokey Ass Message Board' started by spiertb, Mar 1, 2015.
  1. spiertb
    spiertb
    I had a Mallory Unilite rebuilt by them and installed it in my 390 Fairlane. Usually I had to crank it forever to get it to start-then it ran fine. A couple of times I ran the battery completely dead without it starting. Other times it started O.K. Should I have used a coil other than the stock Ford. I had a resister in the circuit as directed. I took it out and installed a stock FoMoCo distributer and it starts right off. I'd rather run the Mallory as it looks cooler with the crab top. Thanks. Syl
  2. spiertb
    spiertb
    Surely someone can help me!! Syl
  3. fiftiescat
    fiftiescat
    from NY
    Run the Ford distributor and send the Mallory back to be checked. If you know the Mallory unit checks out OK, then start your diagnosis on your end. Use what ever components they reccomend. IE: coil, resistor, etc...
  4. mammyjammer
    mammyjammer
    from Area 51
    Century Performance has good Unilite troubleshooting info on their website.
    Unilites need a resistor and are fussy about coils erc.
    I have had good luck with them on my FEs
  5. spiertb
    spiertb
    What did you use for a coil? Syl
  6. 4tford
    4tford
    you need to make sure the distributor gets full twelve volts to function correctly. If your feed the dist after the ballast that could be why you crank so long. 445691d1407355890-mallory-ylm624av-distributor-installation-malloryunilitewiring.jpg
  7. mammyjammer
    mammyjammer
    from Area 51
    I can't see a part number on it, but it it is the round canister style Mallory coil that Mallory recommends.
  8. doyoulikesleds
    doyoulikesleds
    did you add a resistor into the factory power wire to the coil ford cars have one in that wire already
  9. mammyjammer
    mammyjammer
    from Area 51
    I replaced the factory ballast resistor with the Mallory resistor. ....btw I have a 58
