Technical Mallory crab distributor help
Discussion in 'Traditional Hot Rods' started by 31ster, Nov 28, 2017.
  1. 31ster
    31ster
    Hello, I'm trying to install this 2 bolt distributor and I'm having trouble identifying the correct wiring schematic. My distributor which is a 5072001H has a red, brown and yellow wire while all the pictures I've found online has red, green, and brown wiring. Is it as simple as the yellow and green are the same? Thanks 20171128_222008.jpg 20171128_221907.jpg
  2. it would appear that the red is your 12 volt feed from the ignition, brown should be your engine ground and that yellow should connect to the coil from what I could see from the Wizard's diagrams fwiw
  3. 31ster
    31ster
    Thanks slot! That's what I was thinking but didn't want to burn anything up
