Technical Main drive gear bearing retainer seal question
Discussion in 'Traditional Hot Rods' started by edwardlloyd, Nov 28, 2013.
  1. edwardlloyd
    edwardlloyd
    from Germany
    Ford 3-speed transmission main drive gear retainer.
    I pressed the oil seal in then realised I'd fitted it the wrong way round. I did check but somehow on the way to the press I didn't re-check and pressed it in. The rubber lip pointing away from the oil. Do the seals work both ways or will it leak? Has anyone done this, like I did - duh - and found it leaked? Annoying because I'll need to order another one if I pull it out.
    Thanks
    Ed
  2. R Pope
    R Pope
    Bite the bullet and pull it out.
  3. Christom
    Christom
    Oops! :mad: Bugger!
