well i need some of you old magnesium wheel experts help , i have a pair of magnesium spindle wheels with o/t (i think) volvo or v.w. rotors and this is it no calipers the old rodder that built these is , with spirit in the sky passed on , and the calipers were since long gone probably with some of his other fine items , anyway if you can help, please p.m or let me know , and also out of all the others ive collected thru the years what style are these as my other spindle mts have the 5 ear center cap mounting pad and my boly on also , these arent as pointed as the funny car 5 spokes as i have some of them also , these rotors are 11.5 diameter and as close as i can msure the caliper is 2.25 center bolt , could be metric , thanks for any info kevin
Sorry can't help ya, but those are GORGEOUS wheels! Best I could guess is they're made for Airheart calipers.
i know his freind stated he was a machinest from haddies , and they all talked like they were volvo ot vw type 3 , i guess maybe ill try checking a airheart book thanks
shame they drilled em.... first styles aren't as common as the later versions. take a look back about the mid 70's and see what was being used .....or look into some small wildwood or such. might find something close. I have some small strange that are tiny but only use one piston. former wheel guy
i understand the drilling issue , but i guess back in the 70-80s they wanted to get some brakes on them and they actually look like lug nuts they way he mounted and machined the counter bors on the rotor , ive been checking a few of the post and the volvos are looking like they were a hot conversion back then , just trying to find some info and sizes so i can find out what to hunt for at the parts counter , and then i had never seen this style spindle wheel without the mount boss for center caps
Whats the bolt spacing on the caliper bracket? I know some of the single piston calipers Airheart made had a small spacing
as close as i can tell 2.25 un;ess metric , bolts look like 7/16 fine that mount it , rotors 11.5 dia thanks kevin
i guess i check with airheart , if i can get them on line , see if a tech guy might know , and maybe the euro auto house counter guy , thanks for your help
Bing search came up with this image under Hurst caliper. Looks like these could work with them brackets.
http://www.bing.com/images/search?q...FF0CAC684AA2643D3F861B28D9B25&selectedIndex=5 http://static.speedwaymotors.com/images/charts/107-30100001.jpg
Single piston VW Rabbit disc calipers may work, if there´s no room for piston between the dics and the wheel. Otherwise Wilwood SC1/2/3 single piston calipers may work and look the part too.
