Made a grille insert today......not sure if I like it
Discussion in 'The Hokey Ass Message Board' started by Painterman, Dec 26, 2007.
  1. junkmonger
    junkmonger
    That or a confessional. I guess it depends on how old you are. I think I used that stuff in a high school metal shop project too. I'd go with the polished stainless screen, but it's your car.
  2. Painterman
    Painterman
    You're right! Now I know why it looks so familiar!..............Forgive me Father, for I have sinned...........................
  3. congo's dad
    congo's dad
    Grille Loox EXCELLENT sort of early-30's Pontiac
  4. Kustom7777
    Kustom7777
    from Austin, TX
    i dont normally give my opinion when i dont like something, but you asked,,,,,looks like the stuff they use on storm doors or radiator covers in an apartment,,,
    there are a lot of cool expanded metal designs available,,someone posted a thread here not too long ago with places to buy expanded metal...id check out some other options,,sorry, but that stuff just looks kinda cheap to me,,,JUST my opinion obviously
  5. VonMoldy
    VonMoldy
    from UTARRGH!
    i think it looks cool but needs more depth like put a chrome bead around the outside and maybe set it further back in the shell it would look pretty sweet.
  6. Painterman
    Painterman
    No offense taken. Opinions are all over the map on this one. Like all things, it boils down to personal preference. I really wasn't looking for anyone to tell me what to do, just seeing what everyone thought.
  7. fortypickup
    fortypickup
    from Nebraska
    The big question is...Do you like it? If you do, then you would not be posting this! :) Who cares what everyone else thinks! Does it fit your Rods theme?
  8. 50dodge4x4
    50dodge4x4
    Way back when I built my 35 Dodge, I ended up building 3 grill inserts before I found the one I liked best. I ran each version for a year to see if it worked for me. Some are a real pain to clean the bug juice off of, looks like that one may be a pain to clean up, after a summer evening trip near the river/lake/pond. If its going to be there, might as well be functional. Gene
  9. cliff bryan
    cliff bryan
    I think it looks good dewd...not tacky at all!
  10. resqd37Zep
    resqd37Zep
    from Nor Cal
    Just set it a little deeper in the shell. Loose the shine and it'll be all good.
  11. Painterman
    Painterman
    I think you hit the nail on the head. This is what is really bugging me the most. Even though it's a cut up pickup that nobody ever did "back then", it still has a early 50's flavor to the rest of the truck. The grille just doesn't fit. Maybe if I sold the 40 wheels and tires and put radirs on it. Then it would "feel" right. ;)
  12. publicenemy1925
    publicenemy1925
    from OKC, OK
    I'm not diggin it. I seen that mesh at the home depot and it's hard for me to relate to any other way. Everyone dances to a different tune. I like the rest of your ride.
  13. 46highboypu
    46highboypu
    Painterman,
    Im new to this list and slowly finding my around surfing to find others with project similar to mine. That's how I found you (bobbers etc.). I've already learned one thing, if ask for an opinion you'll get 30* who say they like it, 10* who actually give good help and advice, and 60* who want to tell you how stupid they think you are. I'm all for guys who try to do it themselves, no skool, no rules.
    My reason for writing, I looked into mesh like that, behind the grill, to protect the aluminum (yeah I know, too new) radiator in my truck. All I found was pretty much yours and I was concerned about air flow. My situation is different than yours but I think I may try common aluminum screen, really from doors.
    I would like to see some pictures of your ride if you would. Here is my homemade grill which is for my '46.
    46highboypu
    noel_cummins@yahoo.com
  14. maybe if the pattern was tilted at 45 degrees the vertical lines would help
    try acid etching some or just scuffing it a bit also
    any reason ya dint get copper/brass instead?
  15. premium
    premium
    from Goergia
  16. pasadenahotrod
    pasadenahotrod
    from Texas
    No matter what you do to that stuff it will always and forever look like what it is and that IS NOT material for a car or truck grille, new, old or otherwise.
    You asked for opinions because after you installed it you knew but just couldn't jerk it out and can it without reinforcement from others. Nothing wrong with that.
    Make up a template and lay out some round or square bar stock in a vertical or horizontal pattern. Perhaps a mic of large and small bares or a wide vertical center section of larger bars and side, either vertical or horizontal side sections. It's a little more work than screen material but it is CAR stuff.
  17. Killer
    Killer
    round the edges of the grill (by the insert) with some 1/4 rod...
  18. DrJ
    DrJ
    Looks good to me!
    I decided drawer pulls would just invite brat kids to destroy mine pronto...
    I used the pattern that's just two sizes of round holes. I figure it's at least 1/2 open and cooling improved over a round bar grill. I think round bars cause air drag through a grill just like open tires cause more drag than enclosed fenders.
    Mine is tipped back some so I turned the pattern to the 45º angle so the pattern didn't go "down hill" at the sides and think the pattern works better that way.
    I used a cutdown piece of door trim off a '67 Volvo down the center.
