Technical machine work
Discussion in 'The Hokey Ass Message Board' started by robtlor, Dec 5, 2017.
  1. robtlor
    robtlor
    from Lincoln NE
    What are you guys paying for machine work on engine block? In Lincoln NE. Clean and magnaflux block, magnaflux turn and polish crank, R & R cam bearings freeze plugs, bore and hone cylinders, R & R pistons from rods. $525.00. Hows this compare? Bob
    henryj1951 likes this.
  2. gimpyshotrods
    gimpyshotrods
    It does not compare. Real estate where I live is easily 625% of what it is where you live.
  3. henryj1951
    henryj1951
    from USA
    You are within 25bucks one way or the other.... so i'd say you're in the ballpark.
  4. Sounds like a deal to me.
    30 line items and it averages out to $17.50 each
    1 Clean block
    2 Magna-flux block
    3 Magna-flux crack
    4 Cut and polish crank
    5 Cam bearings
    6 Freeze plugs
    14 Bore X8
    22 Hone X8
    30 Piston R&R X8
  5. Mill heads and block, refit three wrist pins, clean parts, fit bearings, polish and balance crankshaft,
    valve job with one exhaust seat. $ 1000.00
  6. That's less than 1/2 price here in Washington. Get it done before he changes his prices.
    gimpyshotrods likes this.
  7. 402BOSSMAN
    402BOSSMAN
    I'm far more expensive and in Nebraska. If you are from Lincoln..... Spanel?
  8. Sheep Dip
    Sheep Dip
    from Central Ca
    I checked about 2 yrs ago for complete machine service on a 327 with new parts, my crank, less heads.. and a rotating assembly was $2500.
    Checked 2 different reputable shops and they were neck and neck with prices.
  9. robtlor
    robtlor
    from Lincoln NE
    402Bossman, this price came from Car Quest, west O street, Lincoln.
  10. That's a bit more than I pay here even with the exchange. But not much.
