friend of mine knew i had just got my lathe working and saw this pile of tooling at the scrap yard and bought it for me. i have a 14" atlas lathe. will any of this work? can any one tell me what the tools do and how they can be used? the stuff that won't work for me, can anybody use? there are buckets with more of the same not shown. i numbered them to identify each for discussion.
Not much looks useful. Look for USA names on the HSS tool chunks. 2) just drill bits 13) cutoff blades 14) is prob a part of a shop made measuring set. That is the ball of a ball and socket. 11) are for a Geometric threading Die 10) is prob that body 3) just HSS lathe tool bits 5) boring bars prob for a mill adjustable boring head 7) form tools for a specific hole shape 9) V threading tools for a Armstrong holder
to use numbers 2 and 5 i would chuck them up in the lathe and move the part into it? or would i need a chuck a carriage to move it into the spinning part?
#2 = drill bits, screw machine length, mounted in bushings. #5 = Boring bars, for accurately opening up holes.
Yes 2 and 5 are very basic turning operations. They attach to the tool post/ carriage and the get slid over into the turning workpiece.
so i will need some way to hold them on the carriage. i have a tool post and a square tool holder, that the shims would be for.
there is a lot of stuff here, i want to keep just the stuff that i MAY use someday. i do not expect to use this for any super precision machine work. i just want to be able to get myself out of a jamb for those times a part can't be bought or something needs to be fitted or adapted. i am guessing i will not need the hydraulic valve tooling or the thread stuff.
Well, you definitely want to keep the drill holders, the HSS turn tool bits, and the boring bars. For sure.
For what you would get for it hang on to all of it. as you get used to your lathe you will find more uses ..
thanks, so the stuff would fill two 5 gallon buckets, how many should i keep? a coffee can of each? all the ones i have peeled the rubber coating off of appear to be freshly sharpened.
there is one thing about a lathe, the more combinations of tools you own and the more creative you are, the more uses you can have for it. there is no real limitations. lots of sites like the link above, along with forums to get you some great ideas. I miss having a lathe around badly but just don't have the room. a good toolmaker is really nothing more than someone with an amazing 3d imagination and math skills.
#8 look like piloted spotfacers, useful in a lathe or a drill press for putting a flat machined surface around a drilled hole in an otherwise unfinished casting.
You have mostly tooling from a production machine shop that ran automatic screw machines. #11 are chasers for an H&G die head, pretty worthless with out the die head itself, and you don't have one. #9 are circular cut off tools for Brown & Sharpe tool posts, screw machine only. #'s 2 and 3 are drills and reamers in bushings to fit in Boyer & Schultz adjustable drill holders that fit a #2 Brown & Sharpe turret. #7 are purpose ground form drills that fit the B&S drill holders. The tooling in the bottom right pic is for various second operation drilling. These jigs were made for a dedicated job by the shops tool room. Looks like you have some misc. tooling from what was left from yet another American small business that was auctioned off, and the un bought stuff was scrapped. I know this because I went through this when I was forced to close our 55 year old small screw machine shop in 2010.
Top picture, orange and white item might be a cat.... But I agree that most tooling I see is screw machine related. Those are often as short and stubby as possible for high-speed operations. #9 looks like cams of some sort.
