Hot Rods M/T valve covers seem kinda cool again.
Discussion in 'The Hokey Ass Message Board' started by Rocky, Apr 13, 2019.
  1. Dyce
    Dyce
    The early ones are cool, but the later sbc have the breather holes located over rocker arms. If you run a pcv valve the engine WILL burn about a quart to every 50 miles. I plan on running the early covers on my model a since the pcv will go to the rear of the block.
    loudbang and enloe like this.
  2. Dooley
    Dooley
    from Buffalo NY
    You realize the new ones come with baffles or you can make them to fix this?
    loudbang, Deuces and enloe like this.
  3. Dyce
    Dyce
    The ones I had bad experiences with had only a plate to act as a baffle. The plate is common to all of the aftermarket covers I've had, m/t just put the pcv in a bad spot. I try to use the lt1 z28/corvette covers on all of my engines because the baffles in the original covers are hard to beat.
  4. Mr T body
    Mr T body
    Alliance Vendor
    from SoCal
    There were 3 different style baffles MT/Holley used in covers. There were 2 different width rectangular with lips on the edges and a flat round one. The rectangular with the larger lips work best. I think I still have NOS baffles around here somewhere......
    loudbang and Deuces like this.
  5. Mr T body
    Mr T body
    Alliance Vendor
    from SoCal
    Dug some old stuff out to show the differences. What you're looking at are original replacement parts for the SBC and BBC covers (241-217, rear) and everything else (241-216, front). However, throughout production the main differences (regardless of application) was the width of the baffle and the lip height. I've had the best luck with oil control by using the narrow baffle with the taller lips (241-216). Though it's narrower it seems to shroud the PCV better than the wider one with a shorter lip.
    BTW, the main difference fit-wise is the Chevy cover baffles had slightly narrower mounting screw centers than the others. You can use non-Chevy baffles if you take a rat tail file to the slots.
  6. saltflats
    saltflats
    from Missouri
    Going to restore these Chevy covers for my dragster.
  7. quick85
    quick85
    While I agree with Blue One (I always preferred the finned Z-28 covers), I had to buy
    these special "350 LT-1" covers. They were $25.00 for the pair. Like most everyone
    else, he just wanted them gone.
  8. CudaChick1968
    CudaChick1968
    I've restored and customized a bunch of those over the years! So many in fact ...
    .... that Indeed, Inc. (an employee headhunter) thinks he works at my shop LOL!!!!
  9. Gasser 57
    Gasser 57
    from New Jersey
    I can't think of a time when M/T valve covers weren't cool.
  10. hrm2k
    hrm2k
    My MT valve covers in action in the back seat of my 65 Corvair
  11. The HellyDid
    The HellyDid
    from Florida
    Like to see the Corvair it's in. I'm in love with my 20190510_140527.jpeg Mr. Gaskets
