Up for grabs is a brand new swing pedal assembly made by Lucky's Speed Shop. These are a very well made and beefed up version on Ansen pedals, and for whatever reason they are discontinued.. I picked this set up a few years ago , but since decided to go in another direction, so these are up for grabs- Included a GM brake light switch, push rods and rubber pedal covers. Also included is a MC core- They retail for $399. These are $275 plus the ride.. I've also attached some tech info from Lucky's website: Pedal Mounting Bracket thickness increased from 1/8″ to 3/16" Pedal thickness increased from ¼” to 3/8″… more secure feeling during panic stops. Correct pedal ratio for proper operation. Pedal pivot diameter increased from ¾” to 1″. Pedal pivot features a High-Temp Dry Lube Bronze Flange Bearing providing excellent rotational movement along with NO oil seepage, lubrication or thrust loading issues. 4140 pivot shaft assures low friction pedal movement and superior strength Precision clevises, pins and hardware. Excellent pedal spacing to provide comfortable feel along while fitting into the smallest of foot box areas. Period correct Pedal Pads. Integrated clutch return stop and stoplight switch mounting. CAD designed, Laser cut, 100% TIG welded. GM Stoplight switch is included.
