Hi all, I need some advice on what oil types and grades to run in my rebuilt driveline please. 1955 Chevy 235ci straight 6 - I've been told to go for 20W-50. Is that ok? 1985 Brog Warner T5 NWC - what do I use? Is it true that I should add some regular SAE 30 in there along with the trans fluid? GM 12 bolt axle - no lsd. - What grade? All advice grategully recieved. Many thanks, Mark.
SAE 30, no detergent oil in a 235 unless it's converted to a full flow oil filter. You don't want it loosening up crap in there because there's no place for it to go, and even if it has a factory filter it's a bypass filter and does not filter all of the oil.
