Lowering springs reference chart.
Discussion in 'The Hokey Ass Message Board' started by alfredfromchicago, Apr 11, 2013.
  1. Has anyone compiled a list of springs to lower cars like the 3" Aerostar springs for the Shoebox fords?
    I'd really like to find an economical drop front and rear coil spring sets for my 59' Chevy or 60' Cadillac. i'd be interested in 55 pontiacs, Tri chevys, or my 59 olds also. (These have leaves in the rear.)
    Thanks! Any advice would be appreciated.
  2. I am also looking for a spring chart. I did some searching to see if a there was a Moog coil spring chart on the net and could not find anything.
    Perhaps someone on the HAMB can point in the right direction!
  3. MOOG catalogs used to have dimensional and load charts in the back. Might look for a newer version at a real parts house or a WD.
  4. hoop98
    hoop98
    from Texas
    I put the Moog and other charts into an Excel spreadsheet.
    You can go to the file menu and download it from the link below.
    I have also added some functionality, such as the ability to compare springs of different makes under the same loads. The dropdowns allow you to filter to only see springs that may fit your car.
    The motion ratio of .58 in the chart can be changed if you know yours, .58 is typical SLA type, in this case a 1964 chevy impala.
    The point 58 means that for every 1 inch the wheel moves it compresses the spring .58 inches.
    The compare shows what the difference in ride height between two springs would be.
    You can link to it here Spring Chart
  5. This is great....! Thanks!
    Eric
  6. hoop98
    hoop98
    from Texas
    Eric, remember to put 1/2 of your front weight as the wheel rate, if you don't know the motion ratio use .55 for front.
    Hoop
  7. What I was just looking at was the possibility of a pair of rear coils for the rear of my 62 wagon that would keep the same approximate spring rate (499) but be about 2" shorter. The stock rear wagon spring is PN6041, the sedan rear spring is 6033 With a few quick filters on spring rate you can dial in some options and sort on the installed height. I added an OD column just for the hell of it.
    Thanks again!
    <TABLE style="WIDTH: 676pt; BORDER-COLLAPSE: collapse" border=0 cellSpacing=0 cellPadding=0 width=906><COLGROUP><COL style="WIDTH: 44pt; mso-width-source: userset; mso-width-alt: 2104" span=2 width=59><COL style="WIDTH: 44pt; mso-width-source: userset; mso-width-alt: 2104" width=59><COL style="WIDTH: 44pt; mso-width-source: userset; mso-width-alt: 2104" width=59><COL style="WIDTH: 44pt; mso-width-source: userset; mso-width-alt: 2104" span=2 width=59><COL style="WIDTH: 44pt; mso-width-source: userset; mso-width-alt: 2104" span=2 width=59><COL style="WIDTH: 44pt; mso-width-source: userset; mso-width-alt: 2104" span=3 width=59><COL style="WIDTH: 44pt; mso-width-source: userset; mso-width-alt: 2104" width=59><COL style="WIDTH: 44pt; mso-width-source: userset; mso-width-alt: 2104" width=59><COL style="WIDTH: 44pt; mso-width-source: userset; mso-width-alt: 2104" width=59><COL style="WIDTH: 60pt; mso-width-source: userset; mso-width-alt: 2844" width=80><TBODY><TR style="HEIGHT: 28.2pt" height=38><TD style="BORDER-BOTTOM: black 1pt solid; BORDER-LEFT: black 1pt solid; BACKGROUND-COLOR: transparent; WIDTH: 44pt; HEIGHT: 28.2pt; BORDER-TOP: black 1pt solid; BORDER-RIGHT: black 1pt solid" class=xl67 height=38 width=59> </TD><TD style="BORDER-BOTTOM: black 1pt solid; BORDER-LEFT: black; BACKGROUND-COLOR: transparent; WIDTH: 44pt; BORDER-TOP: black 1pt solid; BORDER-RIGHT: black 1pt solid" class=xl67 width=59>OD</TD><TD style="BORDER-BOTTOM: black 1pt solid; BORDER-LEFT: black; BACKGROUND-COLOR: transparent; WIDTH: 44pt; BORDER-TOP: black 1pt solid; BORDER-RIGHT: black 1pt solid" class=xl66 width=59>Inside Dia</TD><TD style="BORDER-BOTTOM: black 1pt solid; BORDER-LEFT: black; BACKGROUND-COLOR: transparent; WIDTH: 44pt; BORDER-TOP: black 1pt solid; BORDER-RIGHT: black 1pt solid" class=xl64 width=59>Bar Dia</TD><TD style="BORDER-BOTTOM: black 1pt solid; BORDER-LEFT: black; BACKGROUND-COLOR: transparent; WIDTH: 44pt; BORDER-TOP: black 1pt solid; BORDER-RIGHT: black 1pt solid" class=xl69 width=59>Spring Rate</TD><TD style="BORDER-BOTTOM: black 1pt solid; BORDER-LEFT: black; BACKGROUND-COLOR: transparent; WIDTH: 44pt; BORDER-TOP: black 1pt solid; BORDER-RIGHT: black 1pt solid" class=xl69 width=59>Load (lbs)</TD><TD style="BORDER-BOTTOM: black 1pt solid; BORDER-LEFT: black; BACKGROUND-COLOR: transparent; WIDTH: 44pt; BORDER-TOP: black 1pt solid; BORDER-RIGHT: black 1pt solid" class=xl66 width=59>Installed Height</TD><TD style="BORDER-BOTTOM: black 1pt solid; BORDER-LEFT: black; BACKGROUND-COLOR: transparent; WIDTH: 44pt; BORDER-TOP: black 1pt solid; BORDER-RIGHT: black 1pt solid" class=xl66 width=59>Free Height</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: black; BACKGROUND-COLOR: transparent; WIDTH: 44pt; BORDER-TOP: #ebe9ed; BORDER-RIGHT: black 1pt solid" class=xl65 width=59>End Type 1</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: black; BACKGROUND-COLOR: transparent; WIDTH: 44pt; BORDER-TOP: #ebe9ed; BORDER-RIGHT: black 1pt solid" class=xl65 width=59>End Type 2</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: black; BACKGROUND-COLOR: transparent; WIDTH: 44pt; BORDER-TOP: #ebe9ed; BORDER-RIGHT: black 1pt solid" class=xl65 width=59>Wheel Load</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: black; BACKGROUND-COLOR: transparent; WIDTH: 44pt; BORDER-TOP: #ebe9ed; BORDER-RIGHT: black 1pt solid" class=xl72 width=59>Motion Ratio</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: black; BACKGROUND-COLOR: transparent; WIDTH: 44pt; BORDER-TOP: #ebe9ed; BORDER-RIGHT: black 1pt solid" class=xl73 width=59>Wheel Rate</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: black; BACKGROUND-COLOR: transparent; WIDTH: 44pt; BORDER-TOP: #ebe9ed; BORDER-RIGHT: black 1pt solid" class=xl75 width=59>Compare Height</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; WIDTH: 60pt; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" width=80>notes</TD></TR><TR style="HEIGHT: 14.4pt" height=19><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: #5b9bd5; HEIGHT: 14.4pt; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" class=xl83 height=19>6041</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: #5b9bd5; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" class=xl83>5.086</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: #5b9bd5; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" class=xl84 align=right>3.65</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: #5b9bd5; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" class=xl84 align=right>0.718</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: #5b9bd5; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" class=xl85 align=right>499</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: #5b9bd5; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" class=xl85 align=right>1552</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: #5b9bd5; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" class=xl86 align=right>14.01</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: #5b9bd5; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" class=xl86 align=right>17.12</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: #5b9bd5; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" class=xl84>TG</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: #5b9bd5; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" class=xl84>TG</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: #5b9bd5; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" class=xl84 align=right>900</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: #5b9bd5; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" class=xl83>0.58</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: #5b9bd5; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" class=xl87>168</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: #5b9bd5; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" class=xl88 align=right>24.2</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: #5b9bd5; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" class=xl84>wagon</TD></TR><TR style="HEIGHT: 14.4pt" height=19><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; HEIGHT: 14.4pt; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" class=xl68 height=19>658A</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" class=xl68>5.184</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" align=right>3.81</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" align=right>0.687</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" class=xl70 align=right>404</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" class=xl70 align=right>1552</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" class=xl71 align=right>13.05</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" class=xl71 align=right>16.89</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed">TG</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed">TG</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" align=right>900</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" class=xl68>0.58</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" class=xl74>136</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" class=xl76 align=right>22.5</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed"></TD></TR><TR style="HEIGHT: 14.4pt" height=19><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; HEIGHT: 14.4pt; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" class=xl68 height=19>6084</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" class=xl68>5.162</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" align=right>3.82</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" align=right>0.671</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" class=xl70 align=right>377</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" class=xl70 align=right>1552</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" class=xl71 align=right>12.67</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" class=xl71 align=right>16.79</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed">TG</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed">TG</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" align=right>900</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" class=xl68>0.58</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" class=xl74>127</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" class=xl76 align=right>21.9</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed"></TD></TR><TR style="HEIGHT: 14.4pt" height=19><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; HEIGHT: 14.4pt; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" class=xl68 height=19>6322</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" class=xl68>5.23</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" align=right>3.85</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" align=right>0.69</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" class=xl70 align=right>404</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" class=xl70 align=right>1552</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" class=xl71 align=right>12.35</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" class=xl71 align=right>16.19</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed">TG</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed">TG</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" align=right>900</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" class=xl68>0.58</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" class=xl74>136</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" class=xl76 align=right>21.3</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed"></TD></TR><TR style="HEIGHT: 14.4pt" height=19><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: #ffc000; HEIGHT: 14.4pt; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" class=xl89 height=19>6033</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: #ffc000; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" class=xl89>4.982</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: #ffc000; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" class=xl90 align=right>3.67</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: #ffc000; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" class=xl90 align=right>0.656</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: #ffc000; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" class=xl91 align=right>370</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: #ffc000; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" class=xl91 align=right>1552</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: #ffc000; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" class=xl92 align=right>12.25</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: #ffc000; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" class=xl92 align=right>16.44</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: #ffc000; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" class=xl90>TG</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: #ffc000; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" class=xl90>TG</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: #ffc000; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" class=xl90 align=right>900</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: #ffc000; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" class=xl89>0.58</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: #ffc000; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" class=xl93>124</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: #ffc000; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" class=xl94 align=right>21.1</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: #ffc000; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" class=xl90>coupe</TD></TR><TR style="HEIGHT: 14.4pt" height=19><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; HEIGHT: 14.4pt; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" class=xl68 height=19>6320</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" class=xl68>4.96</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" align=right>3.68</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" align=right>0.64</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" class=xl70 align=right>380</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" class=xl70 align=right>1552</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" class=xl71 align=right>11.21</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" class=xl71 align=right>15.29</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed">TG</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed">TG</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" align=right>900</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" class=xl68>0.58</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" class=xl74>128</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" class=xl76 align=right>19.3</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed"></TD></TR><TR style="HEIGHT: 14.4pt" height=19><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; HEIGHT: 14.4pt; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" class=xl68 height=19>6308</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" class=xl68>4.96</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" align=right>3.68</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" align=right>0.64</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" class=xl70 align=right>380</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" class=xl70 align=right>1552</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" class=xl71 align=right>10.90</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" class=xl71 align=right>14.98</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed">TG</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed">TG</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" align=right>900</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" class=xl68>0.58</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" class=xl74>128</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" class=xl76 align=right>18.8</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed"></TD></TR><TR style="HEIGHT: 14.4pt" height=19><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; HEIGHT: 14.4pt; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" class=xl68 height=19>5762</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" class=xl68>5.137</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" align=right>3.825</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" align=right>0.656</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" class=xl70 align=right>474</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" class=xl70 align=right>1552</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" class=xl71 align=right>9.86</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" class=xl71 align=right>13.13</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed">TG</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed">TG</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" align=right>900</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" class=xl68>0.58</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" class=xl74>159</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" class=xl76 align=right>17.0</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed"></TD></TR><TR style="HEIGHT: 14.4pt" height=19><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; HEIGHT: 14.4pt; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" class=xl68 height=19>81037</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" class=xl68>4.613</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" align=right>3.333</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" align=right>0.64</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" class=xl70 align=right>512</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" class=xl70 align=right>1552</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" class=xl71 align=right>9.83</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" class=xl71 align=right>12.86</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed">TG</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed">TG</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" align=right>900</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" class=xl68>0.58</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" class=xl74>172</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" class=xl76 align=right>16.9</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed"></TD></TR><TR style="HEIGHT: 14.4pt" height=19><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; HEIGHT: 14.4pt; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" class=xl68 height=19>5758</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" class=xl68>5.137</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" align=right>3.825</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" align=right>0.656</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" class=xl70 align=right>474</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" class=xl70 align=right>1552</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" class=xl71 align=right>9.67</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" class=xl71 align=right>12.94</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed">TG</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed">TG</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" align=right>900</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" class=xl68>0.58</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" class=xl74>159</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" class=xl76 align=right>16.7</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed"></TD></TR><TR style="HEIGHT: 14.4pt" height=19><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; HEIGHT: 14.4pt; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" class=xl68 height=19>81039</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" class=xl68>4.613</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" align=right>3.333</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" align=right>0.64</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" class=xl70 align=right>512</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" class=xl70 align=right>1552</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" class=xl71 align=right>8.97</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" class=xl71 align=right>12.00</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed">TG</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed">TG</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" align=right>900</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" class=xl68>0.58</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" class=xl74>172</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" class=xl76 align=right>15.5</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed"></TD></TR><TR style="HEIGHT: 14.4pt" height=19><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; HEIGHT: 14.4pt; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" class=xl68 height=19>CC205</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" class=xl68>4.53</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" align=right>3.312</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" align=right>0.609</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" class=xl70 align=right>405</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" class=xl70 align=right>1552</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" class=xl71 align=right>8.61</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" class=xl71 align=right>12.44</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed">TG</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed">TG</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" align=right>900</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" class=xl68>0.58</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" class=xl74>136</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" class=xl76 align=right>14.8</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed"></TD></TR><TR style="HEIGHT: 14.4pt" height=19><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; HEIGHT: 14.4pt; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" class=xl68 height=19>6434</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" class=xl68>4.696</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" align=right>3.51</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" align=right>0.593</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" class=xl70 align=right>373</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" class=xl70 align=right>1552</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" class=xl71 align=right>8.34</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" class=xl71 align=right>12.50</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed">TG</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed">TG</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" align=right>900</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" class=xl68>0.58</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" class=xl74>125</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed" class=xl76 align=right>14.4</TD><TD style="BORDER-BOTTOM: #ebe9ed; BORDER-LEFT: #ebe9ed; BACKGROUND-COLOR: transparent; BORDER-TOP: #ebe9ed; BORDER-RIGHT: #ebe9ed"></TD></TR></TBODY></TABLE>
  8. hoop98
    hoop98
    from Texas
    Eric, what kind of 62 Wagon do you have, here is the cat for a 62 chevy.
  9. Mine is a 1835 V8 Impala 6 passenger wagon. Based on the chart "C". The nine passenger 45 series is heavier yet.
  10. hoop98
    hoop98
    from Texas
    Take a look at this;
  11. supervert
    supervert
    I started a thread on this once before but Ryan deleted it because it wasn't hamb worthy,
    S10 springs also share the same mounting configuration and I'd as the aeros. Just a bit taller and softer.
  12. The 6310C looks really close to maintaining the original rate after being cut. I like that.
    Can you explain the order in which you updated the calcs?
    To get the comparison did you update the wheel load cell, then calculate or change the motion ratio to get the 2200lb load value?
    Which cell did you modify to reflect the cut height? On the second example a free height of 16.36 to 15.5 = .86 free height cut. I am trying to understand the compare height versus the installed height. Your note shows a .8 drop (15.3-14.5) in compare height but the installed height is .52 drop (9.89-9.37)
  13. hoop98
    hoop98
    from Texas
    I used the deflection rate at spring and wheel to tell me the installed motion ratio.
    I then changed the wheel load to get the rated load.
    I used the cut spring tab to calculate the spring rate change when cutting the spring.
    Installed height divides the load by spring rate to get deflection and subtracts from free height.
    Compare height is the installed height times the reciprocal of the motion ratio.
    So the compare height change is 1.548 (1/.646) * the installed height.
    Simple eh? PS the 6310 is a Camaro front spring. Remember we are comparing published spring specs, you need to double check things before installing.
  14. Thanks for the info!
    As soon as I figure out how to figure it out, I figure i'll get out and do some figureing.
  15. hoop98
    hoop98
    from Texas
    Figures :)
  16. Russco
    Russco
    from Central IL
    I have a moog book I've kept for years, keep in mind that many of the older springs were way softer than what's run today. Running a stiffer spring likely will help the handling and not hurt the ride much if at all. A common spring muscle car guys use is the brook wood wagon front spring and cut it down to desired height. I've personally done this the ride and handling was much better.
