wondering if you can run 2 lowering blocks per side? i have a 51 chevy car with stock springs and open rearend, and i have 4 blocks that are 1.5" each, which would give me 3 inches per side. can you use 2 blocks per side and do it safely? i want to make sure before i purchase them.
I wouldn't. Best to get a set of 3" blocks, otherwise it's like building on a house of cards, if you know what I mean.
It isn't wise in the least. you can usually find "lift" blocks at 4x4 shops that will give you the drop you want. They may be a bit harder to find for those narrow springs though.
i bought the car in my avatar as you see it!! has nothing to do with the lowering blocks!! thanks for the input. that's what i figured, but thought i'd check here just to make sure.
