Technical lowering a 46 Ford 2 inches in the front
Discussion in 'Traditional Hot Rods' started by silversink, Jun 28, 2020.
Tags:
  1. silversink
    silversink
    Is it posable to lower a stock axle 2 inches and not screw up the steering by pulling leaves?
  2. woodiewagon46
    woodiewagon46
    from New York
    I don't think that it's possible to remove enough leaves to lower your front end 2".
  3. olscrounger
    olscrounger
    Try it--not that hard to remove and try then put back if not what you like. Probably has 11 or 13 leaves? go down to 9 and see.
    Weedburner 40 likes this.
  4. Larry W
    Larry W
    from kansas
    reverse the eyes
    dana barlow likes this.
  5. JWL115C
    JWL115C
    Longer shackles work too.
    olscrounger likes this.
  6. Jalopy Joker
    Jalopy Joker
    get roughly 1/2" lower with each (every other and not the very top one) leaf removed - shorter gas shocks will help the ride
  7. Who has done this? I heard that they make the front end hard to handle.
  8. sdroadster
    sdroadster
    If you reverse arch the main leaf, and make some shackles 1" over stock length, it will put you in the ballpark. When we were kids everybody I knew had longer shackles. They were often a graded project in High School metal shop. They work best on 42-48 Fords because they have a factory panhard rod.
    Hnstray, 56don and olscrounger like this.
  9. 302GMC
    302GMC
    from Idaho
    Car or truck ?
  10. Tim
    Tim
    from KCMO
  11. Cosmo50
    Cosmo50
    I got 2" shackles from Vern Tardels. They work really well. I have a 41 and it didn't come with a panhard bar. I got one from Speedway Motors. I haven't noticed any big difference in the handling.
    56don likes this.
  12. alanp561
    alanp561
    I don't know if I'd want to pull the second spring out of the pack which you'd have to do if you reversed the eyes on the main. It stiffens up the main spring and to me, seems kind of necessary on a full fendered 46. My 46 Merc weighs 3545 pounds. Your stock shackles are already longer than those little ones hanging on all these much lighter 20's and 30's coupes and roadsters and yours should be hanging pretty much straight up and down. You've got a panhard bar in there, too. Maybe pull the third, fifth and seventh to see where you'd wind up, might work better.
  13. general gow
    general gow
    MODERATOR
    I usually just shorted the second leaf an appropriate amount to allow for normal travel.
    sdroadster and olscrounger like this.
