Lowering 47 Dodge
Discussion in 'The Hokey Ass Message Board' started by dagizmoguy, Dec 27, 2011.
  1. dagizmoguy
    dagizmoguy
    from Seattle
    [​IMG][​IMG]I want to lower my 47 Dodge. I thought I'd use 2" drop blocks in the rear and I've got some dropped uprights for the front. The deal is I've got 15" wheels and I like the look of the meaty tires so I don't want to get smaller front wheels so Uh Oh, the fender isn't gonna clear. My idea is to open up the front part of the wheel well at the same angle it is now so I'll be able to like, turn. I'm hoping for feedback on the practicality of this idea cosmetically since I'm having trouble visualizing it. Any thoughts would be appreciated....
    Many thanks,
    David
  2. 41 C28
    41 C28
    My 48 Dodge is bagged, running 15" wheels, when its down the turning radius is very limited.
  3. dagizmoguy
    dagizmoguy
    from Seattle
    VERY nice!
    That's the very look I'm looking for.......
  4. Sweet old Mopar 41 C28! Makes you wonder why we don't see more of them..........E
  5. Captain Geech
    Captain Geech
    Gettin ready to lower mine not sure exactly how but will keep you posted on what we do
  6. dagizmoguy
    dagizmoguy
    from Seattle
    Thanks Cap,
    I'm looking forward to it...
  7. INJUNTOM
    INJUNTOM
  8. Cruiser
    Cruiser
    See if you have more space toward the inner fender well, maybe you can get a narrower 5" wheel 15" with a more inward space and gain some turning radius. I wouldn't cut on my wheel wells unless you can redo them to look stock after cutting.
    The curve in the well lip is what gives strength to the wheel well. I would put in a bump stop, to stop you from bending up the wheel well when turning. I would rather rub my inner wheel well more then the outer. Good luck
    CRUISER :cool:
  9. Ingo#147
    Ingo#147
    from Germany
    My Old 46 Sedan. 3" Drop Coil from Camaro on front and 2" Blocks at rear.
    14" Wire Wheels and 205/70r14 Tires.
    Sold some Years ago. Now the Friend Drop it with Airride.
    #Ingo
  10. I just want to drop the back of mine....and Im running 15" tires.....but they are kinda tall......
  11. George
    George
    On my stock height '48 Plym changing rear tires is a PITA! Jack up body, insert jackstands, jack up axel & squeeze wheel out between axle & fender, not much room!
  12. James Curl
    James Curl
    Just try getting that fat spare into the well and back out again. I have P205 R 75 15 radials on my 48 and it is all I can do to get the spare in the wheel well in the trunk and back out again. To change the rear tire I carry a two ton trolly jack and a jack stand to put under the frame after raising it about as high as it will go then use the jack to lift the rear end high enough to get the spare on.
  13. George
    George
    That's what I'm running also! not fun!
