I have 1930 model A i bought last year. I am trying to improve a few things. I like driving it around as much as i can. Its chopped. I am not sure what kind of my seat mine is, but when i drive the car, my right lower leg rests on the B&M shifter. It starts to bother me and sometimes i kick it out of gear. It originally had a hurst handle on it forming a T, that really hurt. I am wondering if there is a lower shifter out there? Not a lot of room in there. The pictures are deceiving. I know my options to cut this shifter down or change the seat so i dont need to sit bow legged. Any other ideas? Thanks again for the help.
The early mustangs had a low type of shifter,it would bolt flat to your floor,it had a T type of handle on them.it is fairly simple to hook up,just has the lever sticking out of the bottom,has a bezel with the letters for PRND12. They were quite popular back in the day,would be worth a look,should be pretty reasonable cost as well. Harvey
A 350TH? How about a tail mount Gennie shifter? It will move the shifter closer to the seat and away from your knee.
All right. Thanks again for the help. There is a here lesson to learn. Evaluate your problem completely before asking for help. I assumed that the shifter was hooked up by some linkage that would be difficult to move. I did not consider that this is a hot rod and that it is not an original car with perfect fitting pieces. I started preparing a mustang shifter i have on the shelf to install when KevKo said "I assume that shifter has a cable. Can you move it over to the right? Or farther back?" Thats when it hit me how my lack of experience is showing. Great answer. It looks like i can slide it back 1 1/2" without showing the cut carpet from the original location. That should do it. Had i looked at the problem first and not asked, I could have found the solution. Thanks
I will wait for winter to do the work. I will add some information to this thread in case someone later on has a question related to this. My th350 has a cable connecting the transmission to the shifter. There is no linkage. Therefore, the shifter can go anywhere I want it to go. Thanks again
I believe that shifter is what is called the star shifter. Yes, cable operated as you figured out. Sent from dumb operator on a smart phone
