LOW static dropped drivers
Discussion in 'The Hokey Ass Message Board' started by The Shocker, Jun 5, 2011.
  1. htweelz
    htweelz
    from Maryland
    Absolutely. That is the definition of cool!:cool:
  2. 65Chevy
    65Chevy
    Here's some pictures of my cousins truck. A 51 Chebby 3100 lowered 6" all around.
  3. ibcalaveras
    ibcalaveras
    Here my parts chaser. it's static dropped.
  4. peeduh
    peeduh
    from atx
  5. flatout51
    flatout51
    Bring back this thread. Let's see more low static drop!!! Heres my shoebox coupe 20190808_174016.jpeg 20190730_114524.jpeg
    Sent from my SM-G977U using The H.A.M.B. mobile app
    OG lil E and Tim like this.
  6. Front cross member is the lowest point underneath at about 3.5 inches-goes down the road just fine-a sharp driveway can usually be navigated at an angle without catching the bumper
    Turbo442, flatout51, Tim and 2 others like this.
  7. These are/were my lowest. Bags pfffftttt! 136.JPG 010.JPG
  8. Here's my '50 chevy....no juice, no assist. Actually rides like a dream and glides right down the road without hitting too much if you watch what you are doing.
    OG lil E, Moriarity, Jay71 and 10 others like this.
  9. treb11
    treb11
  10. Grumpy
    Grumpy
    from NE Ohio
  11. My F100.
    FRONT: reversed spring eyes, 3 inch drop axle, 3 leaves removed, rear hanger sectioned 2 inches, still need to do a 2 inch kick on the frame at the front hanger.
    REAR: reversed spring eyes, 3 leaves removed, rear hangers moved up 2 inches, extended rear shackles, flipped front hangers, still could move flipped front hanger up 2 inches.
  12. flatout51
    flatout51
    This cars pretty low considering it has 28.5" tall tires all the way around. 5" dropped Sids axle, reverse eye main with leaves removed in the front. Chassis engineering low parallel leaf kit in the rear. Will probably get a lowering block to level it out this winter. IMG_20191003_182438_837.jpeg IMG_20191003_182438_840.jpeg
    Sancho and williebill like this.
  13. My 59 Mercury was a pretty low static car that I drove every day for a lot of years...[​IMG]
    OG lil E, Sancho and williebill like this.
  14. [​IMG]
  15. Country Joe
    Country Joe
    My 36 Dodge is 3 inches off the pavement at the running boards dodge (9).jpg
    OG lil E likes this.
  16. hillbilly4008
    hillbilly4008
    from Rome NY
    Got any more pics of that '48? Side shot perhaps? Specs on the suspension setup?
  17. Only about 3.5" off the running board brackets. The Axle is the lowest point, so I figure if I can run it over I will be fine. If it hits the axle.....Well lets not think about that. No scrub line concerns, even with the tall sidewall tires.
    Only trouble I have had is occasionally dragging a running board over a speed bump when I am straddling it so I take big ones at an angle.
    Jay71 likes this.
  18. krbstr
    krbstr
    My old ‘50 pulling in the LSRU. Frame was about 3” off the pavement. Rode ok for what it was and only got stuck on one speed bump!
    OG lil E and D-Russ like this.
  19. The front splash apron was 3" from the ground. HRP
    Knghtcadi, Jay71 and D-Russ like this.
    My '29 with a '35 axle & reversed eye spring...
    anthony myrick and drdave like this.
    My '46 had a GM sub with 2" drop spindles and 2" drop springs...
    OG lil E and drdave like this.
    My '63 C10 with '84 C10 crossmember swap, 2" drop spindles and 2" drop springs...
  23. Gman0046
    Gman0046
    2" drop spindles and cut coils in the rear. Just a tad too low. Speed humps can be a problem, drive shaft hits the floor with passengers in the back seat and luggage in the trunk. IMG_0812.JPG
    i.rant likes this.
  24. Knghtcadi
    Knghtcadi
    That’s beautiful, can you give me all the details how you dropped it and wheel and tire sizes it looks spot on
  25. 18n57
    18n57
    IMG_3546.JPG I drove this, using some care in driveways, etc
    Jim Bouchard likes this.
  26. j hansen
    j hansen
    Country Joe and OG lil E like this.
  27. 2935ford
    2935ford
    Mine is right where I want it. Now to soften up those rear coilovers!
  28. ...all my rides have static drop, my55 is probly the lowest....BTW, you know why we lower our cars?...cuz most of us are "down to earth people". lol
    18n57 likes this.
