Low profile 727 trans mount???
Discussion in 'The Hokey Ass Message Board' started by indianmark, Aug 16, 2009.
  1. indianmark
    indianmark
    Anyone know if there are any 727 trans mounts out there that have a low profile? I don't want to use the stock type mount because of the low hoop of the stock 727 crossmember. A GM type mount would be great but the holes are way off where they mount to the trans. Trans is a 77 - 727
  2. RopeSeals???
    RopeSeals???
    Try looking at a Anchor P/N 2272 Trans Mount...
    It's been a while since I've messed with a TF so I might be wrong :)
  3. indianmark
    indianmark
    Any idea what year, make & model that anchor mount is? I could check it at the local parts store. It looks too tall. I need clearance and don't want my crossmember hanging too low.
    Thanks
  4. RopeSeals???
    RopeSeals???
    I nicked the photo from O'reillys, so they must stock it...
    '66 Dodge Polara is what I guessed... Most auto parts stores can cross that Anchor part number over if they stock another brand...
    You might end up adapting something from GM to make it work. Maybe weld the GM mount onto the Chrysler base...
  5. indianmark
    indianmark
    I don't want to weld to the rubber mount and the bolt holes to the trans are about 1" narrower than the GM
    There must be something out there, what are you Mopar guys using in rods???
  6. swifty
    swifty
    I'm using a Valiant one on my 727. It's similar to the pic above but has 2 bolts.I'd say the height of it would be the same as pictured. I made the trans mount to suit it so height wasn't a problem.
    swifty
  7. George
    George
    I used the OEM mount, ran 2X2 behind it & welded verticle plate on either side with a cross bolt.
  8. Sorry, I'm at work and don't have my reference materials with me... BUT my 71 Road Runner uses a "loop" type trans mount with the bolt that goes through the center of the isolator. (Similar to the '73 & up motor mounts) It might be a little lower profile?
    Better yet...
    Here ya go... from http://www.aandatrans.com/Departments/Chrysler-727-Trans/Mounts.aspx
    AA295
    727/904 (also stick) Rear Trans Mount 1970-1974 E-Body OR 1971-1974 B-Body
    $19.95
    <INPUT id=ctl00_MainContentHolder_DataList1_ctl00_AddToCartImageButton style="BORDER-TOP-WIDTH: 0px; BORDER-LEFT-WIDTH: 0px; BORDER-BOTTOM-WIDTH: 0px; BORDER-RIGHT-WIDTH: 0px" type=image alt="Add To Cart" src="http://www.aandatrans.com/BVModules/Themes/A&A%20Trans/images/buttons/AddToCart.png" name=ctl00$MainContentHolder$DataList1$ctl00$AddToCartImageButton>
    AA145
    727/904 (also stick) Rear Trans Mount 1966-1970 B-Body OR 1967-1972 A-Body
    $19.95
    <INPUT id=ctl00_MainContentHolder_DataList1_ctl01_AddToCartImageButton style="BORDER-TOP-WIDTH: 0px; BORDER-LEFT-WIDTH: 0px; BORDER-BOTTOM-WIDTH: 0px; BORDER-RIGHT-WIDTH: 0px" type=image alt="Add To Cart" src="http://www.aandatrans.com/BVModules/Themes/A&A%20Trans/images/buttons/AddToCart.png" name=ctl00$MainContentHolder$DataList1$ctl01$AddToCartImageButton>
    In case you don't know, an E body is a Dodge Challenger or Plymouth Barracuda (from 70-74) and a B Body is a Plymouth Road Runner, Dodge Charger, etc. from those years. This is just in case you get a keyboard jockey for a parts counterperson and they INSIST on knowing "yearmakeandmodel" in their first sentence... :)
  9. mopar210
    mopar210
    i used a 1975 cordoba trans mount , picked it up from the local napa store
  10. George
    George
    That's the 1 I used.
  11. X426X
    X426X
    from OhiO
    Thats the one I like to use too when there are ride height and/or clearance issues.
    :cool:
  12. indianmark
    indianmark
    Thanks ajmopar, that looks like the ticket. I will try Imperial services tommorow.
    My local parts store say they can't find it. Thanks again I knew I could count on the Hambers
  13. Piper106
    Piper106
    Highjack.
    Wondering if I could use thed same mounts on my 904 TorqueFlite???
    Does the 904 TorqueFlite have the same bolt spacing as the 727 ??
    Piper106
  14. yes the 904 uses the same mount location and bolt spacing as the 727
  15. BigBlockMopar
    BigBlockMopar
    '62-'64 Chrysler transmission mounts are also low profile, but they are square on top.
    They are only about 1.5" high I think. Originally they were used with a large spring on top of them between the mount and the transmission.
  16. George
    George
    '60 Plyms had the coil spring also.
  17. COOL, thanks for the additional info after my post! And here I thought that I knew a lot about Mopars!!! Good stuff to know!
  18. indianmark
    indianmark
    Got my trans mount from Imperial services today. It is exactly what I wanted, a little pricey at $79 but just what I wanted. Thanks to ajmopar and everyone else for their input. I knew I could count one the vast experience of the Hambers to help me find it.
