Hot Rods Low flathead compression
Discussion in 'The Hokey Ass Message Board' started by rodderbilly, Oct 28, 2018.
  1. Hi all hambers ... after lot of smoke from oil filler tube today I check the compression on my 8ba....all cylinders are around 60 65 psi.... engine around 130 deg...... Time to rebuild the engine I know..... Is 0.125 bore over and 3.75 stroke.... What you suggest for a more bore and a good stroke? Thanks
