I'm going to be running a '64 327 in my truck and wanted a corvette style air cleaner to go with the valve covers I got. When I found out how much one cost I decided to try making my own. Here's what I used for inspiration:
I went to the pick and pull and found an air cleaner I liked the size/shape of. This one came from an 87 Dodge Dakota
Then I cut the snorkel off the front of it and layed out my cuts in tape on what used to be the backside of the air cleaner. I used my dremel style tool to make the cuts and a round file to do the corners.
Here is the final result after a little bondo and alot of sanding. I used a gloss aluminum paint to match the valve covers. The plan is to paint the intake orange with a chrome oil fill tube. I painted some wire mesh black and epoxied it in behind the holes. I also welded a plate on the air cleaner lid to create a squared off mounting place for a 327 valve cover sticker.
Bowie is right, it's 65 corvette. I went to a corvette site looking at the reproduction 60's air cleaners. When I saw this one I liked the look of it and it seemed to be the easiest to copy.
Nice work regardless. In the spirit of hotrodding, have some inspiration, then develop a plan to make it your own and even better, while using limited funds....
