I have one of those. To date it's only been used for set up. Mine has issues. Who ever machined it was off a bit. For it to work on my Offy manifold It needed spacers or to remove some of the web in the center. Once mounted with spacers I noticed it didn't appear square to the front of the block. I set it up on an empty block, sure enough. Off by 6 degrees to crankshaft center line. Also this one is not drilled for any kind of front mount. For my motor that is actually a 38 motor it needs to push the Fan mount 3/8" further forward for the belt to line up. I've talked with a found ry about just casting a new one for me. Once I get back on my Roadster project this will most likely happen and I'll run maybe 10 parts so I can recover my costs. I don't know that this one is Wrong but it don't work with my manifold or lower pulley reguardless of it not being square to the block. The Wizzard The Wizzard
is it for sale? I have a friend that can weld it up and remachine it. if anything I have a caster that can cast them. if I can use it ill send you a good one that I have cast. let me know billy
