Technical Looking for info on this beehive oil filter
Discussion in 'The Hokey Ass Message Board' started by Mike Paul, Aug 5, 2018.
  1. Mike Paul
    Mike Paul
    picked this up at a swap meet today. It's missing the nut to hold the cover on but I think I can fab one up. Does anyone know anything about it? Brand? What element does it take? thanks
    Squablow and Max Gearhead like this.
  2. Dirty Dug
    Dirty Dug
    It's a Filcoolator. It takes the same cartridge as a stock flathead oil filter.
  3. 51504bat
    51504bat
    Can't tell from the photos if the top has the spring that goes between the filter cartridge and the top like a stock unit. My guess is that it needs one. I've got a junk stock filter cartridge with the top bolt and spring you can have if you think they would work on the filter.
  4. Mike Paul
    Mike Paul
    On the stock filters that I looked at the top bolt screws "into" the tube coming up through the filter and mine the top bolt is 1/2" fine thread and screws "onto" the tube
  5. RoadsterDom
    RoadsterDom
    Mike if you want I can take my cap off tomorrow and show you what should be there, it’s a little
    More than just a simple nut but nothing complicated
    lowrd likes this.
  6. Mike Paul
    Mike Paul
    Yes, thank you
  7. 41rodderz
    41rodderz
    from Oregon
    I think I have seen reproduction filcoolator decal that go on lid on evilbay before. I believe that originals are cast and reproductions like Speedway sells are machined finish.
  8. RoadsterDom
    RoadsterDom
    6FA925B3-DBD0-41F0-90E3-1231633A9B32.jpeg 49A4E52A-50B4-4D68-B193-1A8313A24522.jpeg 5A921501-A5C2-493A-AEA1-3DF1D64DCE20.jpeg 527B7757-BEDF-4CC3-8045-E20CA7FBF693.jpeg Pictures as promised .
    Under the big spring right at the top there are four holes that you can’t really see that also allow oil to pass through from The inside . On the inside of the cap there is the thread to allow it to screw onto the Center of the body and also another small spring , I’m guessing this spring is there to keep the cap under tension and stop it vibrating loose . There is also the big main cup that keeps the oil filter in place and under tension inside the casing
    Hope that makes sense , any questions ask away I’ll try and answer them the best I can
  9. Squablow
    Squablow
    Good score, that's a cool part.
  10. Mike Paul
    Mike Paul
    I see, it is a little more complicated than just a wing nut.
  11. Mike Paul
    Mike Paul
    Can you post a pic of the top bolt and spring you have?
  12. 51504bat
    51504bat
  13. 51504bat
    51504bat
  14. Mike Paul
    Mike Paul
  15. Mike Paul
    Mike Paul
    It looks like the washer part is pressed onto the the threaded thing that sticks out the top sandwiching the spring between the top and the washer. I see speedway sells a repop of this filter. I wonder if the top parts are the same as mine. Anyone have a speedway repop they could take the cover off and post a couple pics of the inside? Thanks
