Projects Looking for ideas on how to attach my license plates.
Discussion in 'Traditional Customs' started by Karl Schofield, Aug 21, 2017.
  1. Karl Schofield
    Karl Schofield
    Here in Japan we are required to run both plates. I need to redo both front and back (Japanese plates are a odd size) on my '51 fleetline. Let's see what you got.
  2. 19Fordy
    19Fordy
    Buy two of these and cut and weld them to fit the Japanese plate.
    They are clean and simple and look great.
    of course, if you can fine two old originals it would be great.
    LOU WELLS likes this.
  3. Karl Schofield
    Karl Schofield
    Two of what?
  4. BuckeyeBuicks
    BuckeyeBuicks
    from ohio
    Don't they have zip ties in Japan?
    Truck64, LOU WELLS and Karl Schofield like this.
  5. Jalopy Joker
    Jalopy Joker
    do your bumpers have holes for mounting brackets to mount plates? post pics
    Karl Schofield likes this.
  6. 19Fordy
    19Fordy
  7. Karl Schofield
    Karl Schofield
    They do but that another problem the LAN office (DMV) seals your rear plate on. Special aluminum seal.
  8. Karl Schofield
    Karl Schofield
    No mounting holes, I'll get some pics soon. Rear plate is mount between splash shield and trunk lid now. But the Japanese plate is too big to mount flat. I have one of the afore mentioned front plate mounts for the rear. The front plate mount is my main problem. I want something that will just mount the plate and not add to the front bumper.
    Lowdownfab likes this.
  9. REALY? ?? Not cool.
    upspirate likes this.
  10. straykatkustoms
    straykatkustoms
    I like 19fordy's idea. You might need to extend it to fit the Japan tag. A plan B would be using Kaiser bumper guards. They are good size and would need cut down to fit your plate. It would be easier to cut one down than to add too... Keep the faith brother you will come up with a kool idea....
    20914366_10214686417692940_698158649419771033_n.jpg 20882367_10214686414812868_4652858681279120874_n.jpg
  11. Don't hack anything on the '51. Get a Japanese chrome or cast frame right there locally, fabricate a sturdy backer board out of 1/8"/3mm aluminum or plastic sheet, make spacer posts of thick wall, aluminum tubing with bolts to hang the frame out far enough to clear any protrusions, use rubber washers if needed. This could look weird on a late model car but on a '51 it would most likely look right at home. When you can't get something to blend in seamlessly, display it prominently. Works every time. (Think continental kit but for license plate.) A mini bumper guard, as suggested, that partly wraps the plate frame might be the cherry on the cupcake.
    This is just off the top of my mind. You're kind of stingy with the details and pix so I have to just imagine what other issues have to be overcome.
  12. Karl Schofield
    Karl Schofield
    The plate was attached with zip ties here. I'd like to keep the front something like this.
  13. Why not just drill a couple of holes and mount the tag with a screw & nut,it's not like your going to harm the chrome.
    How is the front tag mounted on the car beside yours? HRP
  14. tfeverfred
    tfeverfred
    I thought at first that the bumper and tag were of some odd size. That looks like a little common thought would yield an easy solution.
  15. Dick Stevens
    Dick Stevens
    I would look for a license plate bracket from a Japanese brand of auto to mount on your 51.
    tfeverfred likes this.
  16. Bend plate to bumper contour-attach with 3M double sided molding tape...;)
  17. Mr48chev
    My front plate on my 48 pickup is mounted with a bracket that is held on by the nut for the middle bolt in the bumper an bends over (or under I'm not sure at the moment) the bumper and the tag mounts to it the normal way. I think it was a standard rear tag bracket for a 70 something Chevy truck but I'd bet that there are brackets for Japanese truck plates that are quite similar that with a mod or two would work just fine. You should be able to fab one pretty easily that doesn't show at all unless you stand right over the bumper and look down at the plate.
    Cosmo49 likes this.
  18. japchris
    japchris
    from England
    If you don't want to drill the front bumper, could you run a steel bar that curves behind the bumper and that fixes to the bumper iron bolts at either end. Then weld a bracket to the middle of that bar that curves round under and up in front of the bumper to fix the plate to?
    Karl Schofield and Cosmo49 like this.
  19. Mark in Japan
    Mark in Japan
  20. Karl Schofield
    Karl Schofield
  21. Karl Schofield
    Karl Schofield
    Thanks for all the suggestions, once I complete it I will post pics.
  22. Run straps top to bottom on the back side of the bumper with holes that match the License plate, bolt it all together and the license will be where you want it.
