Looking for a pic of 364/401 Buick bellhousing
Discussion in 'The Hokey Ass Message Board' started by rainh8r, Dec 8, 2008.
  1. rainh8r
    rainh8r
    Does anyone have a picture of a 364 or 401 Buick bellhousing? I'm helping a friend look for one and I don't remember what they look like. Thanks, Rob
  2. rainh8r
    rainh8r
    I have found a bellhousing that looks like a regular GM housing at the trans mount face (GM trans bolt pattern), is made of aluminum, and has a round bolt pattern on the block face-not the BOP or Chev pattern. The guy that has it is knowledgable about Buicks and said he took it off a 364 (with the flywheel and clutch) about 20 years ago. I thought Buicks looked like the Olds housing, which is very shallow, while this one is pretty deep-closer to a late model housing in size. Does this sound familiar to anyone? Thanks, Rob
  3. d2_willys
    d2_willys
    from Kansas
    I have a 57 Dynaflow for a 364, that has an aluminum bell housing. Are you looking for a stick bell housing, or just looking at bell bolt patterns? I can certainly furnish a picture of the bell bolt pattern if needed. Let me know.
  4. HEATHEN
    HEATHEN
    from SIDNEY, NY
    All factory nailhead stick shift bell housings were cast iron; you may have an aftermarket (Offenhauser, Speed Gems, Trans Dapt) bell. All nailheads had a ful bell housing, like most modern engines--no small housings like the early Olds/Cadillac. If I can see it, I can tell you for sure.
  5. nailheadroadster
    nailheadroadster
    If you are searching for one you may want to try contacting this place : http://wheatbeltbuick.com/
    Its a mom & pop Buick boneyard and they are always very nice to deal with. Good luck.
  6. nailheadroadster
    nailheadroadster
    Just procured the pics for ya. BTW... there is one on Egay right now.
