I've been known to miss a shift now and then in my Ford and am considering a rev limiter, something simple. I have no MSD box, just a GM HEI distributor, external round coil and a Sun tach. I have a Ford type solenoid on the firewall if that helps. I appreciate any leads on a good one that doesn't break the bank. Thanks!
After my brother discovered the wooden wedge my dad had put up under the carpet, he shortened the throttle rod to the carb the gas pedal went to the floor but the carb never opened all the way. My teenage idiot brother never did figure that one out. MSD and some others make a stand alone rev limiter that are not real expensive and work with any ignition.
Here is one possible solution, I am running the Ignitor III on my 38 Chevy, set at 5500 RPM, a good safety switch because the motor is really starting to run then! And it looks "old" when you look at it. http://pertronix.com/prod/ig/ignitor3/default.aspx
here's two pages of inline rev limiters and launch controllers that run from reasonable to expensive. Maybe one of these will work. https://www.summitracing.com/search...=Ascending&keyword=rev limiter&kr=rev limiter
