Projects look what I brought home
Discussion in 'Traditional Hot Rods' started by pdunn10, Feb 24, 2014.
  1. well, check out what I brought home.
    1931 A chassis, running, stopping, driving.
    Scored 5 original 19" A wheels and rubber
    Along with the 36 wheels that are on it.
    here is the coupe body to go on it.
    I may need to talk to a few of you guys about a few things like if I wanted to find what would be needed to get me legally on the road. He would not sell me the title Even though I am almost positive the title should go with the chassis.
    I finally have something to put my coupe on and have some fun, While I build up my Flathead.
    Sad that the truck will be leaving but damn excited about the coupe:D
  2. [​IMG]
    better pic of coupe body
  3. chevy54man
    chevy54man
    from NC
    Great model A project! Would love your 3 window, wish we lived closer!
  4. Those are 35 wheels. 36 was wide five
  5. Thanks, I did not know that
  6. summersshow
    summersshow
    from NC
    X2 here! and me and chevy54man are even in the same state. lol
  7. kyvetteman
    kyvetteman
    Yep, '35 was the last year Ford produced wire wheels, and they are 16". Very popular too!
    Nice score for a cool project!
  8. 4 banger 4 life
    4 banger 4 life
    from ohio
    Nice score sweet project.
  9. That's B.S. about the title... What kind of shady crap is he planning to do Without the frame with the numbers??
  10. henry29
    henry29
    He probably has the original body to the frame and wants to keep the title with the body.
  11. Olderchild
    Olderchild
    from Ohio
    Could get interesting if you file for a lost title, you got the frame and the numbers, hummmmm getting out the popcorn:D
  12. Olderchild
    Olderchild
    from Ohio
    HELL maybe it's HOT:eek:
  13. ClarkH
    ClarkH
    If the PO is retaining the title, I strongly recommend you at least get a *notarized* bill of sale. If it turns out the PO is using a title with your frame numbers on it, a notarized bill of sale may help you sort out the situation when you go to title your vehicle.
    Of course, it is entirely possible the numbers on the PO's title do not match the numbers on your frame. Frames and engines got swapped out a lot over the years.
    Case in point: my brother and I recently bought a '31 coupe. It's titled by the state as a '31, using the engine's serial number--and that engine number date-codes to 1928.
    So who knows what numbers are on your PO's title. But a solid paper trail can only help you. Good luck!
  14. thanks for the info
    I thought the numbers on the frame were near the motor mount but i did not see any there.
  15. Also what if I register it before he does with my number for his title? would I be able to have the title associated to my chassis? Leaving him with just a body?
  16. 61falcon
    61falcon
  17. That is the idea! I just got the chassis and know some states are easier to deal with and some harder. I have never had to deal with title issues before.
  18. ClarkH
    ClarkH
    Your frame number is on the upper side of the left/driver's frame rail, underneath the cowl. Sometimes they've rotted away. Sometimes they've been ground off by somebody who wanted to keep their title and not have their frame number floating around out there.
  19. Oneshotstriper
    Oneshotstriper
    from Indiana
  20. olskool34
    olskool34
    Looks like a nice chassis to start with. As far as the numbers, chassis nunbers a lot of times do not match the engine numbers as stated above. A ton of A's have had their engines replaced. The frame number is usually under where the cowl area is.
  21. Olderchild
    Olderchild
    from Ohio
    The people in power( PO-PO) can lift the numbers off a frame(even if they have been ground off )if they wish too,
  22. Olderchild
    Olderchild
    from Ohio
    If the police/high way patrol(if they want to) can lift the number off the frame, even if they have been ground off
  23. Olderchild
    Olderchild
    from Ohio
  24. harleyjohn45
    harleyjohn45
    The frame number is on the left side of the frame just behind the bolt that holds the body down. The body has to be lifted to see the frame number. The number will be on the top side of the frame.
    Ford went by the frame number on titles. I just got a 1931 title by having the frame number run thru NM DMV and jumping thru a lot of hoops. My roadster is titled as a 31 ford.
  25. did you just go to dmv and tell them you did not have a title? Or file for a lost title?
  26. indyjps
    indyjps
    Yeah be careful, if he retains the title and you don't have one, he can sit back and wait until you finish the car. Call it in as stolen and come get your work. I would file for lost title with that frame number based on bill of sale. You did get a signed bill of sale, right?
  27. Sweet !
    If anyone wants to check a VIN to see if it's been reported stolen to the National Insurance Crime Bureau here is their link. https://www.nicb.org/theft_and_fraud_awareness/vincheck
    (you do not need to register or create an ID, just fill in the VIN fields)
    This also works on construction equipment and other 'vehicles' with a VIN.
    NOTE: NICB gets their data from several sources, Insurance companies and law enforcement so if someone has a car that was stolen and never reported it wouldn't show up as stolen with this link.
    As for the acid test..."Raising" serial numbers is actually simple physics. They use acid to erode the soft metal around the serial number area. having been compressed, The actual numbers are hardened and stronger than the metal around it so the acid takes longer to erode the compressed metal.
  28. classic gary
    classic gary
    FYI, as an example, here's a pic of the VIN on the frame of my '28. Part of it is under the body.
  29. C-cab dreamer
    C-cab dreamer
    It has already been suggested that you have a signed bill of sale. If I were you I would also make a note on the bill of sale that the seller has the title but refused to give it to you. Can you at least take a photograph of the title?
    If he won't let you do that red flags should be flying. Start your checking right away.
    I know we have different rules here in Canada, but I have covered my backside with paperwork when I bought my car. Not that there was a title available, but it's far easier to CYA now than try and do it later.
  30. I know he plans to register his body with the title he kept. He is putting the body on a custom chassis.
    I wonder what would happen if my number is used by me to re-title my car, then he was to try and use the title to register his.
