Hot Rods lomeza
Discussion in 'The Hokey Ass Message Board' started by lomeza, Apr 6, 2011.
  1. lomeza
    lomeza
    from california
    Hope someone can help. I replaced my 1950 Ford manual steering with a saginaw 605 power steering. Issue is that when I turn the steering wheel left the tires go right. Is this a pitman arm issue. Help!!!
  2. stude_trucks
    stude_trucks
    Nothing is perfect. You'll get use to it. Don't worry about it.
  3. Does the pitman arm point backwards when you have the wheel straight?
  4. alchemy
    alchemy
    Yes it is. Turn the pitman arm 180 degrees.
    Oops, the linkage won't reach now? You chose the wrong orientation steering box.
  5. madhman
    madhman
    move to england
  6. LANCE-SPEED
    LANCE-SPEED
    I'd call Saginaw??
  7. lomeza
    lomeza
    from california
    Come on guys- Is there a part of the linkage that is missing. I did not take apart the system. I`ve been told that there is a gear box that turns the opposite direction but the saginaw 605 does not!
  8. BJR
    BJR
    Quick turn left..... No the other left!
  9. eaglebeak
    eaglebeak
    You now have a spare.........
  10. Mark T
    Mark T
    You put the steering wheel on upside down.
  11. junkcad
    junkcad
    from nashville
    turning is over rated anyway
  12. chaos10meter
    chaos10meter
    from PA.
    It will work like that but it's gonna take a bit to get used to it.
  13. borntowrench
    borntowrench
    Try riding around the block a couple times, it might settle in and start working properly.....
  14. You put a front steer box on a rear steer car. No way to make that work. Start over
  15. tommy
    tommy
    I'd suggest you get someone with some experience to do it for you. I don't think you are qualified to do suspension/steering work. That's not meant to be an insult just a statement of fact. You obviously have not thought it through and this is an area that takes a lot of thought.
  16. Nads
    Nads
    from Hypocrisy
    His posting on forums skills are a bit lacking too. Rubbish in, rubbish out.
  17. That's for damn sure! Never did an intro and uses his name for a thread title
  18. Look for a 525 or 122 manual box, they are rear steer, or look for a 60's Mid-size GM with PS, not a 70's Camaro.
  19. Mark T
    Mark T
    Try a power steering from a 1999-2004 Jeep Grand Cherokee, a bunch of guys are using them on '49-'51 Mercs and '55-'56 Fords. Take a look at the 1952-56 Fords Social group here on the HAMB, a bunch of guys in the group currently have the Jeep box installed and working and a bunch more including myself are working on this setup.
    The Jeep box is far better than the 605.
