I am currently restoring this car and I cannot seem to identify the tail lights used. Here are some photos of the original tail lights on the car and a piece of the original lense. Any help would be greatly appreciated Sent from my iPhone using The H.A.M.B. mobile app
They look like '42-'48 Ford. https://www.google.com/search?q=194...oid-sprint-us&sourceid=chrome-mobile&ie=UTF-8
Thank you Ray but not the same. Of course I have the piece with no part # Sent from my iPhone using H.A.M.B.
BJR, I am glad you posted those. That was my first thought and I went to google for '59 Pontiac images for confirmation and only saw the really wide lenses....which were Bonneville...but didn't see the narrow ones pictured. Thinking my memory was even worse than I knew , but still thinking Pontiac, I found the Tempest I posted above. Glad my initial thought was vindicated here....may not be what the OP is looking for, but is close(r). Ray
I am very thankful of the effort put in here guys. Unfortunately the Pontiac tail lights are a lot different than the ones used on the car. The Pontiacs have what I would call a crown on them. The lenses used had a stainless ring in the recess on the edge of the lense. Sent from my iPhone using H.A.M.B.
Same logghe as the funny car guys? There sons still run the stamping company division- call them and ask. I'll tell you I looked all over the place for a simple oval taillight like that one. Never found one but I'll be watching here Good luck
there are also some late 50s wagons with lights of similar shape, but the details are wrong. 59 plymouth, 58 ford, 59 pontiac for example.
Have you tried the Euro makes. I just did a quick search under 1950s OPEL which was also sold in the U.S.A. but did,nt find anything matching. Then there is still Austin, FIAT, ALFA, Peugeot. Remember the old Peugeot that detective Columbo drove around in , have to think out of the box this time.
The imports usually didn't have a single large lens, they had a few bulbs in there, and a divided lens. They generally had the turn signal separate from the brake light, is why. The later Volvo 544 is an example of a lens that is about the right size/shape, but it covers two bulbs and has a reflector built in.
There were/are some semi truck and trailer tail lights that used that shape (sometimes called a "lozenge" shape). They were pretty basic, flat surface mounts. Your photo is blurry so it's hard to tell if those were transplanted from a car or if they were aftermarket items. When you say "no part number", do you have any other parts of the tails besides the lens piece to check? Is it likely you can replace the whole tails with the next closest thing?
Do you need 1 or 2 lenses? I was just wondering if you had a good lens to look at, is this dimple mirrored on the other side?
1959 Plymouth Suburban Wagon.... I know the chrome that surrounds the lens fits right over the top of a signal stat oval sealed beam tail light and they are like 6 1/2" wide the lens is flat but I seem to recall a convexed one also do a search there on there....the last one is the signal stat ..... Sent from my QTASUN1 using The H.A.M.B. mobile app
Sorry guys for the Slow reply. I have been making some good progress on the car. The tail lights are plastic and the car was built 1959. I need two lenses and all I have Is the broken piece I photographed. I am looking at euro stuff. Sent from my iPhone using H.A.M.B.
