Hot Rods Live Stream…El Mirage
Discussion in 'The Hokey Ass Message Board' started by A Boner, Nov 12, 2023.
  1. A Boner
    A Boner
  2. Stan Back
    Stan Back
    I've always wondered why some crews at Bonneville and El Mirage hold an umbrella or jacket in front of the driver that has the sun in his face . . . and pull it away just before it leaves the line with his eyes are trying to adjust so he can see where he's going.
  3. 05snopro440
    05snopro440
    To keep the direct sun off the driver so they don't have a heat-related episode.
    Mr48chev likes this.
  4. Jalopy Joker
    Jalopy Joker
    good to see that Gene Winfield and Dave Freiburger (Hot Rod / Roadkill) made it out there
  5. Jalopy Joker
    Jalopy Joker
  6. "just before they leave the line" was it key part of Stan Back's post.
    @Stan Back
  7. 05snopro440
    05snopro440
    Which is exactly when it's most critical. All suited up, helmet on, and no airflow.
  8. Mr48chev
    Throw in that most of those cars have been brought up to operating temp when they are three or four cars back in line and have no insulation as far as heat shield.
    I'll have to hunt that video down on Youtube on my tv as my computer is too slow to get them to work right.
    05snopro440 likes this.
  9. I still think you're missing the point. He's talking about seconds before hitting the loud pedal, not the minutes or hours leading up to the go! signal. It's like standing out in the bright sun with a hood over your head then having it pulled off, it takes a bit for your eyes to adjust to the change in light. I think that's the point he's making.
  10. Marty Strode
    Marty Strode
    And HE would know, because he did it for 20 years or so, and did it well !
  11. cornfieldcustoms
    cornfieldcustoms
    Most people are wearing sun glasses, tinted visors or both. Pulling the umbrella away at the line doesnt effect my eyes at all. Its not like i am going from pitch black to direct sun light. It is to keep the sun off the cock pit and driver for heat purposes. Its not that hard of a concept
    Stogy and 05snopro440 like this.
  12. A Boner
    A Boner
  13. 05snopro440
    05snopro440
    That's funny because I think you're missing the point. It's typically very hot on the salt/desert and right before the run the drivers are wearing a lot of gear, it's hot in the car, and there is no airflow. If the eyes adjusting to light is an issue, the individual driver can discuss that with their crew and change their plan, just as they can do for protecting the driver from heat stroke, etc. The eyes adjusting to light is an individual thing, just as their tolerance to heat is. Someone else's approach won't always make sense to everyone else.
  14. jimmy six
    jimmy six
    Elmo Rodge and Happydaze like this.
  15. jimmy six
    jimmy six
    You can see why LSR at El Mirage is not a good spectator sport. If your lucky if 1 car every 10 minutes. Even with a breeze to move the dust it’s a crap shoot whether your engine will be even warm after a 2 hour wait in line after your group number is called up.
    Even Bonneville has gotten bad. To a racer waiting in line it seems the tower doesn’t call for a car until the last one has stopped on the return road and someone has driven over to ask it everything was ok. In the 70’s when I started, when a long course car got to the 5 a short course car was leaving the starting line.
  16. Stan Back
    Stan Back
    While we're on the subject -- black fire suit -- you gotta be kidding!
  17. jimmy six
    jimmy six
    Only in November or October at Bonneville.
  18. Happydaze
    Happydaze
    Me at El Mirage. Must have been a hot day, I think you can see my swollen ankles!
    Chris
  19. cornfieldcustoms
    cornfieldcustoms
    Could be worse, like a white car racing on the salt…
  20. Stan Back
    Stan Back
    Have you read the Rule Book on that? Do you know that we put big, black, circular discs on all corners. Never had a problem when it's been brought up. Clocks have caught it every time. When you surpass our record count (7), ring in with some more knowledge and experience.
    As for starting with the sun directly in your face at Bonneville, you might have caught the sun at its lowest peak. We do it on purpose -- the air's better early. You've got to get out of Impound first (have you been there?) and do that by camping on the south side. You pull up the tapes and get right in front.
  21. cornfieldcustoms
    cornfieldcustoms
    I am very familiar with the rule book, as I am an SCTA tech inspector, and have teched your car before. I have brought up that your car doesnt meet the rule book by not having a contrast color ( other than your small purple letters) and you have have whined your way through. But it is what it is. Dealing with you at bonneville is much like on here with your clear attitude and self importance. But you do you and I will see you in the tech lines on the Salt
  22. Stan Back
    Stan Back
    The rule hasn't changed for 20+ years -- so I'd like to know how you think it's different. Do you know the reason for it in the first place?
  23. cornfieldcustoms
    cornfieldcustoms
    It doesnt matter, you will continue your talk of grandeur and how I dont know what I am talking about.
    Lets get back to the OP topic of the El Mirage live feed.
  24. Stan Back
    Stan Back
    I do think you know what you're talking about. And you should be congratulated for getting in the number of runs to get thru all the requirements after a long trip to the dirt. I don't have the roadster anymore but am proud of what we did with it over the years.
    I'm sure you know the difference between running on the salt and running on the dirt. Both can be different every time you make a run there -- even on the same day. The "Catch 22" with cars, as you know, is that you sometimes have to add more weight to go faster, but then need more H.P. or lower gear to get there.
    I've seen your beautiful car and I wish you success. And I thank you for your work for the organization. I typeset and laid out all the programs for a dozen years or so for a couple of months each, trying to straighten out the entries, but I'm so old now I can't even imagine doing that chore anymore.
    As to the "White Rule", we never had a problem in all the years we raced it. The rule was passed, as I'm sure you know, pertaining to streamliners and other vehicles with enclosed wheels. It was deemed that we were (for 17 years) exempt from that because of the great areas of the car that included the black wheels, the radiator core, the roll cage, and the other color of the exposed chassis. Our car's entry number and class were also painted in another color to the size specifications in the Rule Book. And they were positioned to be easily seen by the starter when he had to radio that information. Never had a problem there.
    Anyway, I'm sorry I didn't make it to Elmer and see all of you run recently. I finally got a guy to fix my 90-year-old two-story roof that weekend -- I'm not allowed by the boss at 81 to do that. I hope to spectate again at the lake and salt -- but I think we're on the same team -- at least in supporting our organization which needs all of us active for the "cause".
    65pacecar likes this.
