Technical Linkage
Discussion in 'The Hokey Ass Message Board' started by LSJUNIPER, Jun 3, 2021.
  1. LSJUNIPER
    LSJUNIPER
    from ct
    9DCB422C-95E5-4436-9139-E6F9A54F7CCE.jpeg 7DD47038-0BC9-48E1-B0C8-EDE8AF26886E.jpeg The linkage is coming in contact with the pump. Can I turn the whole bracket and run the pump 180 degrees from current location?
  2. Moriarity
    Moriarity
    SUPER MODERATOR
    I don't know why not, but will you have firewall clearance for the pump? Is it just the outer stop that is hitting? maybe it could be shorter? or flopped and run the heim joint on the outside and the other closer to the carb? lets see all the carbs and linkage
  3. LSJUNIPER
    LSJUNIPER
    from ct
  4. Mr48chev
    It appears that that particular linkage was designed to be run without a mechanical pump. Stromberg 3 x 2 linkage.jpg
    LSJUNIPER and fauj like this.
  5. Moriarity
    Moriarity
    SUPER MODERATOR
    so, why not move the outer linkage that currently goes to the back carb to the front one, I think that will do the same thing. that is assuming that it is the secondary linkage that hits the pump?
  6. Blake 27
    Blake 27
    Could you run the linkage to the front carb instead of the rear?
    LSJUNIPER and hemihotrod66 like this.
  7. Blake 27
    Blake 27
    Moriarity beat me by three minutes, I've got to learn to type faster.
    LSJUNIPER, hemihotrod66 and Moriarity like this.
  8. bchctybob
    bchctybob
    It looks like you have several options;
    1. Move the secondary linkage to the front carb - easiest and looks right
    2. Rotate the fuel pump mount - it looks like you have room but it may look odd
    3. Cut the flange off the bottom of the tower, rotate where you like it and weld it back on.
    Nice car you're building......
    LSJUNIPER and Moriarity like this.
  9. DDDenny
    Not sure how much travel you are lacking but you could swap that nicely machined (tapered) end stop for a much shorter one and cut off the extra rod length.
    LSJUNIPER likes this.
  10. LSJUNIPER
    LSJUNIPER
    from ct
    I think that may work.
    X38 and Moriarity like this.
  11. LSJUNIPER
    LSJUNIPER
    from ct
    All, thanks for the suggestions.
    Oilguy and Moriarity like this.
  12. JWL115C
    JWL115C
    I had a similar problem where the linkage rod was hitting the distributor. You don't really need the rearmost fitting on the rod. Remove it and cut the rod so that it will be long enough to go through the slide fitting but short enough not to hit the fuel pump.
  13. @LSJUNIPER , let us know how you resolved the linkage problem, with photo.
    Thanks.
  14. LSJUNIPER
    LSJUNIPER
    from ct
    A03A6470-7E2F-486F-9BBD-9A8F463007F8.jpeg B4BA14EF-7A40-496D-BDB9-76A9A29A1E1A.jpeg
    Well there you go, this was an easy fix. Just put the rod to the other side. Gonna work out good.
    '28phonebooth, Moriarity and pprather like this.
