Lincoln Motor into 55 Ford Victoria
Discussion in 'The Hokey Ass Message Board' started by A.P. Photography, Jul 14, 2009.
  1. A.P. Photography
    A.P. Photography
    Got a chance to pick up a 79 Lincoln Versailles that is complete from a friends grandmother. I know the brakes and rear will work on my 55 but what about the Engine/Tranny? It is a 302 and Auto tranny so am thinking it should work or is there something I am not thinking of?
  2. A.P. Photography
    A.P. Photography
  3. 39 All Ford
    39 All Ford
    from Benton AR
    I can't talk from experience for a 55 Vic, but the 302 is a nice compact engine that lends itself well to adaptation. (then engine compatment in my 55 Lincoln would SWALLOW a 302!)
    302 can be had with a front sump or a rear sump. It has been put into everything from light trucks to the Mustang II.
    IMO a 302 is ALMOST as easy to swap as a SBC.
    I have never used an AOD, but everything I have heard says it is a pretty easy swap as well.
    So, I say with 100% certainty that the 302 AOD will work easy chezzy in any engine bay that can hold a Y block.
  4. rustrustler
    rustrustler
    when you take the rear end out save all the pieces as some of the emergency brake brackets are not available from Ford
