Let's Talk Cyclecars
Discussion in 'The Hokey Ass Message Board' started by Bigcheese327, Dec 4, 2007.
  1. Ned Ludd
    Ned Ludd
    Zoran, thanks for this. It's much what I was thinking, except that we'd have several sprockets fixed to a tube around one of the axle shafts. The problem in a higher-performance application would be torque steer, i.e. the long axle shaft winds up under power and unwinds when power is released, resulting in more power first to one wheel and then to the other. It is why the short driveshaft on a transverse front-drive arrangement usually has a narrow waist somewhere along its length, to make it as springy in torsion as the long driveshaft. So one would have to incorporate some sort of torsional spring in the hub etc. to achieve that.
    But I'm investigating other differential options.
    Edit: as long as the diff is open, wind-up shouldn't be a problem, as it would be equalized in the differential's action. So, Stu's arrangement would work perfectly, with the necessary adjustments.
    Things might get a bit hairy with a limited-slip differential, though. The same applies to the principle of a Detroit Locker, for instance, which isn't really a differential at all but an automatically-unlocking spool. That could in principle be widened into a laterally- sliding splined axle with clutches at the wheels, but the haphazard locking and unlocking wouldn't suit this sort of car.
    The consensus in road-racing seems to be moving in the direction of, the grippier the tyres you have, the more sense a plain open diff makes.
    I think the old trials practice of separate left and right handbrakes acting on the respective rear wheels would rather suit the character of a GN/FN, despite being wholly redundant on the originals.
  2. chrisp
    chrisp
    Setup day at Retromobile
    Peugeot Bebe
    Bugatti and Talbot (too big for a cyclecar but too cool)
    Riley
    George Irat
    Renault (AX?)
    BNC
    A row of Bugs
    An other Bug
    Croizemarie
    and a Bugatti a way we rarely see them
  3. Ned Ludd
    Ned Ludd
    Here's an arrangement of "wiggly monkeys" that would work with three dog hubs and six speeds:
  4. motoklas
    motoklas
    from Bern, CH
    Hello Ned,
    I am sure that you will find solutions, design them and make them in the best way that you need and want, for your “special”, and all of us can enjoy in following development of your project, discussing some issues and giving “advices”... Never too old to learn something new – even not of any use in practical way? (thinking on myself at the first place)
    I was thinking about turning things on head (Columbus’s egg):
    • replica of earlier GN, in mater of transmission: entire sprockets/chains/sprockets complete should be fixed to chassis (no any torsional or other unwanted forces on system);
    • from secondary axle with sprockets, instead of belts, use a pair of chains to each of the rear wheels (a`la motorcycle system), or just one chain to differential on the rear axle;
    Chain-type differential could be built or bought... I am not sure for weight, power and way of use of your special, but suppose that belts shouldn't be adequate? Otherwise, they would obtain simple differential function...
    It seems to me that Detroit Locker simply use two free-wheel bearings (one for each side), or sprang-clutches? If it is so, I am afraid that there shouldn't be real differential action:
    • power/torque would be equal to both of wheels just at straights;
    • at curves and corners – only outside wheel should have free-wheeling without power/torque at all, turning faster than half-shafts; - inside wheel should have all the power/torque!
    Not the best solution?
    For sure that two hand-brakes should be helpful if need to have limited differential action (avoid free-wheeling of one wheel over mud and dust)
    For me just fitness for old brain, during short winter days and long nights, waiting to finish my HPV-quadricycle when weather permitt that.
    Ciao,
    Zoran
    Ned Ludd likes this.
  5. motoklas
    motoklas
    from Bern, CH
    ....deleted... (double message)
  6. LeeStohr
    LeeStohr
    from Virginia
    Thank you for the Retromobile photos! Keep them coming if you can, really appreciate it. Wish I was there.
  7. chrisp
    chrisp
    I'll try but I'm there for work so I won't have much time to roam the aisles once it opens to the public.
  8. Ned Ludd
    Ned Ludd
    I was thinking, I'd need a bevel box anyway, and an IRS third member should be the most convenient. That shouldn't have a differential in it, though, so I could replace that with a spool and use the diff on the axle.
    I'm wondering about a nice light bevel box, though, as being ahead of the gearbox it'd see at most less than a third of the torque it'd see in a conventional arrangement.
  9. ebtm3
    ebtm3
    I used the tailrotor gearbox from a Sikorsky heilo in my ersatz Morgan
    Hoib
    brayton engine guy likes this.
  10. ebtm3
    ebtm3
    Hit send too soon- Frank Piasecki used the lower end of an outboard motor for the tailrotor in his first ship--kind it hard to lash it down though as there was no flat surface for mounting, I think that they welded a plate, with gussets to the outer casting, which should have played hell with the gear alignment--but hey--it flew
    Was a long time ago when we cosmetically restored The PV2 at Piasecki Aircraft, that I had the opportunity to sniff around it.
    H
    brayton engine guy and Ned Ludd like this.
  11. motoklas
    motoklas
    from Bern, CH
    Chris,
    It is nice to have such job where you enjoy, or to have a joy for which you are paid?
    Wonderful photos of old automobiles from various categories! Peugeot Bebe and cute Croizemarie are as older and a little more serious brothers of cycle-cars?
    Ciao,
    Zoran
  12. Ned Ludd
    Ned Ludd
    What sort of ratios do those have?
  13. ebtm3
    ebtm3
    Nedd.
    Been a long time, but as I recall the Sikorsky was around 2½-1 with a hunting tooth--so ratio wasn't exact. The outboard I have no idea--not into boats, Not a heck of a lot of help I know. Never even knew what model Sikorsky the thing was out of., as it was a government surplus rebuild. $35. I bought 2 for insurance, but never had a speck of trouble, Last I heard the trike was still running-now on its fifth owner
  14. Kume
    Kume
    has anyone seen results of the Baillon collection auction yet . Some of the predicted prices in the catalogue seemed quite cheep! Wish I was there with a wallet full of euros!
  15. SR100
    SR100
    About 20% of the estimates appear spot-on, many of the rest are insanely low. More entice-to-bid than estimate of selling price. An Amilcar CGSS biplace sport, circa 1927 (which, admittedly needs everything) for only 3000 - 5000 €? Some of the estimates are too low. I'd hate to see some of the sedans cut up for, as Dawie put it, "more obvious cars". There are not many high, or should I say generous, estimates. When I looked a couple of minutes ago, they had not posted results.
  16. belgiumcustomshop
    belgiumcustomshop
    from belgium
    I went to the baillon auction yesterday! Mainly for the amilcar but it was way out of my league! People went crazy yesterday!
    46000€ +20%tax for the amilcar
    50000+tax for the sandford
  17. belgiumcustomshop
    belgiumcustomshop
    from belgium
  18. belgiumcustomshop
    belgiumcustomshop
    from belgium
    44000 for a voisin chassis with engine
    480000 for the hispano suiza
    105000 for a delage d8
    250000 for the bugatti
    625000 for the talbot lago t26
    1 490 000 for the talbot lago t26 grand sport
    25000 for the packard eight
    1 700 000 for the maserati
    And 14 200 000 for the ferrari 250
  19. belgiumcustomshop
    belgiumcustomshop
    from belgium
    All without tax! I was happy to witness it but too bad the most cars went for 3/4 times the estimated price! It certainly filled the room!
    And about the cars: they were nicely displayed and a once in a lifetime opportunity to see so many rare barn finds in one place!
  20. belgiumcustomshop
    belgiumcustomshop
    from belgium
  21. The37Kid
    The37Kid
    Based on the pre auction photos this was my pick of the collection, that roof damage was never shown in the early shots. What was the sale price on it? Bob [​IMG]
  22. belgiumcustomshop
    belgiumcustomshop
    from belgium
    1 490 000€+20% tax
    Nice and rare car with allot of rust and damage ImageUploadedByH.A.M.B.1423299678.650297.jpg
  23. chrisp
    chrisp
    Total sale of the collection reached 25.5 M
    I didn't get a chance to visit anything from the show, too busy in our booth, we even got some interesting offers for the cars we had on display to showcase our restorations capabilities.
  24. fredvv44
    fredvv44
    People go nuts at auctions but there aren't any more of these cars left if you want a project. That Talbot will be worth twice that after restoration.
  25. fnqvmuch
    fnqvmuch
    but did one get away? in the barn but not in the sale, i mean. 8fc90c00-7cb5-11e4-bb26-65fed348e967_Abri-1-avec-Facel-Vega-Excellence-et-Talbot.jpg
  26. Kume
    Kume
    There did seem to be a few that were visible on the original barn photos and not in the auction catalogue.
  27. belgiumcustomshop
    belgiumcustomshop
    from belgium
    Maybe the family decided to
  28. belgiumcustomshop
    belgiumcustomshop
    from belgium
  29. belgiumcustomshop
    belgiumcustomshop
    from belgium
  30. chrisp
    chrisp
    Some didn't make it to the auction, one can imagine also that there have been negotiations on the seller fee, did they put Artcurial and Bonham in competition? Maybe a couple cars instead of cash?
