Let's Talk Cyclecars
Discussion in 'The Hokey Ass Message Board' started by Bigcheese327, Dec 4, 2007.
  1. fredvv44
    fredvv44
    Here is what the swing arm rear end can do. With a locking diff. you would be in real trouble.
  2. ebtm3
    ebtm3
    The epitome of what a car should look like IMHO.
    What is the engine in the GN Parker? Looks similar to OX5 valve gear, but has to be aircooled.
    Herb
  3. banjeaux bob
    banjeaux bob
    from alaska
    Herb ,it is a Cirrus aircraft engine.
  4. banjeaux bob
    banjeaux bob
    from alaska
  5. Ned Ludd
    Ned Ludd
    It shows why that era is called "Vintage".
  6. banjeaux bob
    banjeaux bob
    from alaska
  7. banjeaux bob
    banjeaux bob
    from alaska
    V8 JAP engine in museum mode.Notice the cutaway cylinder...and the cutaway cylinder in the engine behind it.GCL pic... 1782098_708977835847530_4907799533571247992_n.jpg
  8. motoklas
    motoklas
    from Bern, CH
    Hello SR100 and Ned,
    Thank you on information and nice photos of NAMI-1: mistery is solved.
    For most of us, USSR and before that old-Russian history of motorisation is quite gray zone, with a lot of interesiting expamples and mechanical solutions...
    Ciao, Zoran
    banjeaux bob likes this.
  9. banjeaux bob
    banjeaux bob
    from alaska
    1921 Aerocar cyclecar.The Aero Car was the size of a Cyclecar. This two passenger Aero Car weigh in at 150 pounds, wheel base of 60 inch, tread of 30 inches and sold for only $160.00. This automobile was really driven by propeller. The motor could be started from the seat, one lever controlled the engine while a foot lever controlled the brake.
    Aero Car
    The Sheldon F. Reese Co.
    Huron, SD
    1921
    The thrills of an Airplane, the safety of an automobile and the economy of a motorcycle. All were combined in a propeller driven American Automobile designed by Sheldon F. Reese of Huron, SD.
    The Aero Car was capable of 60 MPH and equipped with a twin cylinder engine of six horsepower. Production was unlikely but a protype was built. Image by Marc,text by R.A... 1800242_748845185151797_5396028432957602764_n.jpg
  10. banjeaux bob
    banjeaux bob
    from alaska
    Carden Monocar...marc pic... 10409709_748974875138828_8848052557075331693_n.jpg
    1904135_748975041805478_3701816613557365637_n.jpg 10675638_748976355138680_304273005285206627_n.jpg
    motoklas likes this.
  11. banjeaux bob
    banjeaux bob
    from alaska
    Messershcmitt. I 10155047_709484925796821_1906228288163537959_n.jpg don't think she's going to go for a ride with him.
  12. banjeaux bob
    banjeaux bob
    from alaska
  13. Ned Ludd
    Ned Ludd
    Come to think of it, there were in the Vintage era a number of cars which shared this unusual combination of solid front axle and IRS. Steyr had a few, too, like the Type XII which I believe was the definitive Vienna taxi for many years:
    Also available with commercial bodywork:
    But we digress, as these are way beyond cyclecar scale :)
  14. motoklas
    motoklas
    from Bern, CH
    ... so, just to find similar, but smaller?
    Zoran
    Ned Ludd likes this.
  15. 64 DODGE 440
    64 DODGE 440
    from so cal
  16. banjeaux bob
    banjeaux bob
    from alaska
  17. banjeaux bob
    banjeaux bob
    from alaska
    Amilcar C6,1938 Bol d'Or,driver Georges Grinard. Marc pic... 15289_749160355120280_4309626211542861130_n.jpg
  18. banjeaux bob
    banjeaux bob
    from alaska
  19. motoklas
    motoklas
    from Bern, CH
    Hello Fred,
    I had nice chance to drive both Herald and Spitfire (for short time), some 3 decades ago... Just to say that in my childhood and early youth in Belgrade, we consider any British car as sporting auto, and anything built by Triumph as true sport cars! So, even being something older, I used to drive both of them quite fast across and around city. They were quite lively at rear around corners and sharp curves, especially on wavy surface. I didn't have too much problems having a lot of experience with swing-axle vehicles: Zastava 750 (FIAT 600d made in Serbia under license) and its faster derivatives , than SKODA 1000mb, VW-beetle 1200, RENAULT 8/10 and NSU 120c. All of them had rear engine and rear power, but something modified according to simple swing-axle suspension. NSU was the best of them (but quite dangerous at high speeds – light front end) and next to it was RENAULT, the worst was SKODA. Never could know how to pass curves with it: beside bad rear suspension, front wasn't better including heavy and imprecise steering...
    However, all of them were quite fun to drive, but only when I know and respect limits of autos, road and myself...
    I couldn't be sure for differential-less power: never had auto with blocked or limited differential. Maybe lack of differential shouldn't be too bad for NAMI-1: good power on snow and mud, and under-steer at curves that should compensate regular over-steer (???) and keep power at outside wheel while inside one is over ground in the air. Just theory: maybe all that should lead to disaster during nervous and fast driving...
    Ciao, Zoran
    P.S.: Our racers from National class (sixties and seventies), solved problems (almost) with swing-axles of Zastava 750, when pressed rear coil-springs so much that run almost without any suspension's work, getting "X" layout of wheels instead of "O"...
  20. motoklas
    motoklas
    from Bern, CH
    Hello Ned,
    Theoretically, such different layouts for front and rear suspension should lead to bad road-holding and disasters, but... Probably designers (and industrialists) tried to solve a few problems on the simplest and most practical way. Over (mostly) bad macadam roads of period, they need independent and flexible suspension, so they choose swing-axles for rear, where are passengers and freight. At front they kept solid axles as the most simple type and one that would keep good steering geometry in all circumstances. It would keep wheels in steady (almost) vertical position to ground? Beside, sold axle ares strong and in that period all autos got front brakes... And, they are CHEAPER!)
    Swing-axles at front could be used, but could give nervous suspension and steering over bad roads and fast driving trough curves?
    Ciao, Zoran
  21. banjeaux bob
    banjeaux bob
    from alaska
  22. banjeaux bob
    banjeaux bob
    from alaska
  23. banjeaux bob
    banjeaux bob
    from alaska
  24. banjeaux bob
    banjeaux bob
    from alaska
  25. banjeaux bob
    banjeaux bob
    from alaska
    10526179_711200815582901_6225045145153746269_n.jpg bizarre 3 wheeler
    Stretchmobile likes this.
  26. banjeaux bob
    banjeaux bob
    from alaska
  27. banjeaux bob
    banjeaux bob
    from alaska
    Tonight this thread reached a milestone....
    One MILLION views
    208 pages
    just about seven years and running....
    Stretchmobile, SR100 and Ned Ludd like this.
  28. Ned Ludd
    Ned Ludd
    Hi Zoran
    I suspect that ride quality was the main motivation here. The swing-axles allowed the designer to add the relatively heavy final drive to the sprung mass, which made for a lower resonant frequency for any given spring rate. Given the limited grip afforded by the tyres of the day the favourable camber recovery characteristics of the swing-axles probably outweighed the jacking tendency: the car would likely skid before it found itself in the sort of situation you showed in your previous post. Moreover, because Hans Ledwinka's differential design had the axles swinging about the pinion axis it placed the roll centre at hub level, i.e. roughly the same height as a conventional Hotchkiss drive's. Where U-joints or CV joints are used the roll centre would be a bit higher and exascerbate the jacking tendency.
    The camber recovery characteristics would also have offset the spring-base considerations: the reason why the focus was on IFS elsewhere. The effective spring base of an independent suspension is necessarily equal to the track, unless modified by use of an anti-roll bar (which is ordinarily undamped despite often representing a wheel rate greater than the main springing - the reason I dislike anti-roll bars). Usually the spring base of a solid axle is less than the track, though it is perhaps more accurate to say that it is not necessarily equal to the track. I have been able to devise methods of locating a solid axle which give an effective spring base greater than the track.
    The spring-base issue dominated early suspension development. Because front spring bases tended to be narrower than rear spring bases, there was generally more roll stiffness at the rear for any given spring rate. This created a general oversteering tendency, so much so that bad handling must have been synonymous with oversteer in the minds of early suspension innovators. The appeal of IFS was a front effective spring base equal to the track and less camber recovery than the rear suspension, i.e. that which makes for understeer. I do not think the theory of tyre loading v. slip angles was quite understood, though. I do not think it was articulated by 1930; it certainly was by 1950. Resonant frequency theory was well-known, though: Dr. Lanchester had used it in a suspension design before 1900.
  29. Any IDeas on the convertible and bizarre 3-wheelers?
  30. Ned Ludd
    Ned Ludd
    The green one is a Berkeley: 2-stroke motorbike engine and FWD, made by a manufacturer of caravans (i.e. trailers).
