Let's Talk Cyclecars
Discussion in 'The Hokey Ass Message Board' started by Bigcheese327, Dec 4, 2007.
  1. UKAde
    UKAde
    from Oxford UK
    Dropped the second spring off at a local guy who build tricycles of the pedaling kind , he is an extoolmacker and has a great small workshop ,
    He managed to drill the spring without resorting to his spark eroder we discussed making a set of rear hubs to match the fronts I have and machining the rear axle to mount them ,
    And also machining the kingpin part of the front axle and steering arms , he does have a waiting list for his bicycle stuff but says he may be able to fit me in this side of Christmas ,
    I have now cut the two springs in half to make 4 quarter elliptic springs ,
    I have also sold the chater lea cyclecar I have to finance the rest of the jappic project, the first purchase is going to have to be a new laptop to finish the drawings that need to be sent to the water jet cutting bloke ,
    It's all coming together there even maybe a hint of the correct engine but I'm not getting too excited as so many leads have been fruitless on the engine side
  2. chuxx
    chuxx
    Sounds like you're makin great progress, Ade. Keep it up and I hope the engine lead plays out in a positive way this time. Christmas is right around the corner!
  3. LibertyV12
    LibertyV12
    Hello guys
    what an awsome thread... been reading it and not getting much work done .... some lovely pic gives me loads of ideas..
    At the moment am having a look at building a Briggs & Stratton Flyer replica..
    any ideas on that type of wood to use as the chasis (floor boards)??????
    :D:D:D
    and found this pic on the web ... with no details .... but could be a blast to build or something close
  4. Ned Ludd
    Ned Ludd
    Where are you based, LibertyV12?
  5. banjeaux bob
    banjeaux bob
    from alaska
    Welcome to the HAMB cyclecare thread Liberty V12! They probably used ash for the frame of the little Red Bug.
    BanjeauX Bob
  6. banjeaux bob
    banjeaux bob
    from alaska
    Here are some pictures from Angus Mitchell in Australia.He knows Onelung too.
  7. banjeaux bob
    banjeaux bob
    from alaska
    More from Angus...
  8. banjeaux bob
    banjeaux bob
    from alaska
    1922 Amilcar. Michael image...
  9. banjeaux bob
    banjeaux bob
    from alaska
    Hinstin.Michael image...
  10. LibertyV12
    LibertyV12
    thanks for the info banjeaux bob ...
    have also been told hickory is another very good wood to use ......
  11. banjeaux bob
    banjeaux bob
    from alaska
    Here is our own onelung's 1909 Sizaire et Naudin.It was one of the fastest and most consistent on the Tour De Fleirieu 2012. Angus pics...
  12. banjeaux bob
    banjeaux bob
    from alaska
    1925 Hotchkiss AM. Yes,I know it is a little larger than a cyclecar.It's a lovely car just the same.If you're struggling with this post scroll to the next one!Angus pic...
  13. onelung
    onelung
    from Adelaide
    Don't be too apologetic re the "cyclecar" thing Bob ... I'm interested to see that the 1100cc Amilcars were competing in the cyclecar category, whereas I view them as "light cars" (voitures legeres).
    The body work on that Hotchkiss was incredible ... made using Kauri timber, which is found in New Zealand and New South Wales/Queensland.
    Not to be confused with Karri - an altogether different beast.
  14. banjeaux bob
    banjeaux bob
    from alaska
    Lung,thanks for those beautiful shots of the Hotchkiss!Were the strips glued only ,or were they riveted as well?
  15. onelung
    onelung
    from Adelaide
    You're asking more than I can answer ... sorry Bob :eek:
  16. Ned Ludd
    Ned Ludd
    Years ago I was involved with a woman who made furniture. Those flush-plugged countersunk screw fixings are very much the sort of thing she might do.
  17. banjeaux bob
    banjeaux bob
    from alaska
    #1 Tricycle Simo
    #2 Tricycle Gillet
    Marc pics...
  18. onelung
    onelung
    from Adelaide
    Now that Simo I like! Along with the earlier posted airscrew propelled "thing"...:D
    In passing, I've heard of a cyclecar which is somewhere here in Adelaide, Sth Oz. It was sighted in an establishment which does wicker furniture, etc. ....in the process of having a wicker body fitted. Never heard of the make before (that's not unusual for me) - "Beacon" ... listed in Georgano.
    If I can get to see it I'll pass on the news.
    Speaking of unheard-of car makes, at the recent National Veteran Rally in Queensland I was introduced to a Grout steam car.
    One of the pleasures of veteran motoring is that seemingly no matter how long one's involvement, "new" names still continue to come up.:)
  19. Kume
    Kume
    Fascinating info - I shall have a closer look at the Kerikeri car when next I am up that way. I was wondering how you find driving your sizaire with the sliding Pillar suspension. I understanding that the constant track change can be disconcerting.
  20. noboD
    noboD
    That Simo looks like someone a molested David Bradley tractor. And I LIKE it.
  21. onelung
    onelung
    from Adelaide
    Two points: as I suggested earlier, on anything other than a glass-smooth surface one would not think it had any suspension, front or rear (the unsprung weight involved there is about the same as the Sydney Harbour bridge).
    Second - what track change? So far as I can see there isn't such.:confused:
  22. Ned Ludd
    Ned Ludd
    Sliding-pillar arrangements with kingpin inclination will experience track changes: track will decrease under compression and increase under extension. The Sizaire's pillars seem close to vertical, however. There should be fair amount of scrub radius.
    In roll the track would increase proportionally to the secant of the roll angle, which should be small with so stiff a spring rate, and moreover fairly gradual. That works on off-road VWs that have huge front-wheel travel, so I'd say it's not an issue.
  23. onelung
    onelung
    from Adelaide
    "...The Sizaire's pillars seem close to vertical..."
    They certainly are ... in both a lateral as well as a longitudinal sense. I think I'd need a micrometer to measure the change in track - or for that matter wheelbase, as there's stuff all camber as well.
    And - "scrub radius" ... :confused:
    If this was taken into account when the front end geometry was "designed" by M. Sizaire I'd be somewhat surprised, 'though I might well be selling him short.
  24. Ned Ludd
    Ned Ludd
    Scrub radius: a front wheel will follow a circular path about a point on the ground when steered while the vehicle is standing still. "Scrub radius" is the radius of that circular path. It is zero when the kingpin axis goes through the middle of the tyre contact patch. While this would seem to be desirable geometrically it leaves one with zero steering feel, too: so one would want a little scrub radius. Too much scrub radius does become a problem under braking, though.
    I doubt if M. Sizaire worried unduly about scrub radius, considering that the car had very narrow wheel assemblies no front brakes.
  25. banjeaux bob
    banjeaux bob
    from alaska
    1926 Darmont Special. Vincent Vintage - Revival Montlhery pic...
  26. banjeaux bob
    banjeaux bob
    from alaska
    Morgan burnout. Colin Musgrove pic.
  27. banjeaux bob
    banjeaux bob
    from alaska
    Single cylinder Morgan.Colin Musgrove pic...
  28. onelung
    onelung
    from Adelaide
    Well that sorts out my mind-set that all Morgan 3 wheelers were V-twins!:eek:
  29. banjeaux bob
    banjeaux bob
    from alaska
    Lung,500 cc JAP engine.
    BanjeauX Bob
  30. banjeaux bob
    banjeaux bob
    from alaska
    This picture is from Joris Bergsma of www.prewarcar.com I have no idea what kind of car it is.It is fairly small.It has a boat tail.I like the top and wind up windows.
