lets see the filled model a sedan tops
Discussion in 'The Hokey Ass Message Board' started by crider, Jan 18, 2009.
  1. The Wizard!
    The Wizard!
    S10 Blazer roof works real nice! With Ribs! I may be able to dig up a pic.
  2. crider
    crider
    Also while on the subject of filling tops, for those of you who filled an A, did you leave the wood in or replace it with steel supports? I ask this because my wood is all missing and I'm trying to make up my mind if I want to put it back or just use steel tubing
  3. Von Rigg Fink
    Von Rigg Fink
    from Garage
    im planing on doing this to my Tudor, but I want to put the vynl roof covering back on it once the steel is in place. any suggestions on what to use that doesnt have the ribs..?
    if not stock isnt too bad i guess
    Crider..I bought all new wood for mine
  4. glenn33
    glenn33
    from Browns, IL
    My wood is still pretty good, but I'm replacing it with square tubing. Did that to a buddy's 31 last year and it worked out great.
  5. motoandy
    motoandy
    from MB, SC
    I used a 84 Aerostar roof insert turned backwards. I had to use flat steel to continue the lines and blend into the visor. One for looks and the second was for structure to the flimsy visor.
  6. greenracer
    greenracer
    from sequim wa
    Mine is from a late 60's ford wagon
    <center>
    [​IMG]<br />
    </center>
  7. fitzee
    fitzee
    On the Hambandy build we used a 63 Dodge roof. Has very interesting lines and was easy to install.
  8. Ghost28
    Ghost28
    I bent up some 3/4 square tubing for my chevy. I then outlined the opening with the tubing. then added the cross bars, that I had bent so that they matched each other. The curve of the cross bars will hold the roof panel to a curve. And give me a place to glue the center down, and just weld the outer edge...ghost
  9. crider
    crider
    Fitzee, that dodge roof looks awsome. But I am guessing one of those would be hard to find around here. I'll have to do some lookin though
  10. Model A's came with fenders?
  11. crider
    crider
    Not sure if they came with fenders but I'm thinking of adding them..lol
  12. DO NOT Glue the center down! When finished you will see where it was glued when the temp changes, a cloud comes over, you pull into or out of the shade!:eek:
  13. heatnbeat
    heatnbeat
    from Madera,Ca.
    I was told the same thing But I had tacked the roof to the steel tubing cross supports:( I had to grind the tacks and I inserted some thin insulation between the roof and the cross tubes.No rattle or any other problem:)
  14. I SMELL SMOKE
    I SMELL SMOKE
    thats good advise. thanks
  15. art.flame
    art.flame
    i used a chrysler voyager turned it 180 degree fits like a sucker
  16. art.flame
    art.flame
  17. kieran
    kieran
    from San Diego
    anybody ever make/use a ragtop?
  18. Ghost28
    Ghost28
    Tman. thanks I did'nt think about the temp change, I can see how that could be a problem. After your comment about not using glue I remembered the material used between the roof bows, and roof. On older cars to control vibratiion was more like an upholstery padding thanks again ...ghost
  19. No prob. Walk around a car event some times and look at filled tops.......very enlightening:D
  20. mad-cad
    mad-cad
    I used a 1968 suburban roof turned around 180 deg,no ribs ,easy to fit.The scrap yard charged me about $120 and they cut the roof off and gave me the suburban roof spars which I cut down and used on the sedan roof.
