Features Let's see the dash ~ work in progress or finished.
Discussion in 'The Hokey Ass Message Board' started by HOTRODPRIMER, Apr 22, 2017.
  1. Hollister Kopp
    Hollister Kopp
    Before and after in my '50 shoebox. I'm certainly no craftsman, but I like how it turned out.
  2. mgtstumpy
    mgtstumpy
    Nothing flash, my 35 Chevy Standard with a 35 Master gauge insert
  3. jamesd1502
    jamesd1502
    from san diego
    mad mikey and Fern 54 like this.
  4. Bandit Billy
    Bandit Billy
    Mine got some paint on it finally, I'll put it together next week and give you an updated photo. It'll get some pin-striping to separate the colors later.
  5. goldmountain
    goldmountain
    This is my '40 dash in my T coupe. Been narrowed about 3". The radio speaker grille is a shortened one from a '41 after the '40 one became a melted blob when I tried welding it. Instrument cluster is from information I gleaned from mj40's tech week post. IMG_1005.JPG
  6. Major Carnage
    Major Carnage
    Hey Slim, what speedo was used here?
  7. Major Carnage
    Major Carnage
    Shoebox Ford?
  8. Black_Sheep
    Black_Sheep
  9. 31 B'ville
    31 B'ville
    from SE Pa
    1. All Things Pontiac
  10. lostone
    lostone
    from kansas
    A BIG Thanks goes out to fleetside66! He hooked me up with the beginnings of my dash last week.
    After great lengths of searching I finally id'd the gauge panel I got from him.
    It appears to be a 25' - 26' studebaker cluster. What makes it hard to id is it has 4 small gauge holes vs the common studebaker small 3 hole cluster.
    I found only 2 pics of a stude 4 hole cluster after many many hours of searching the web. It seems to be only on the special 6 model and then only on very few of those so I'm guessing there was a option for a 4th gauge but only on the "Special 6" model.
    The 2 pics are really bad so I couldn't blow them up to try and id the gauges BUT anyway its perfect for my desires!
    I'm thinking it would be perfect set into a 35 to 39 ford dash, with a center waterfall and painted cool vanilla to match the firewall with wood grain behind the cluster and the glove box area. I'm leaving the cluster just as it is, it's to damn perfect to change!!
    Now I just need to find a dash to cut and fit in my 31 tudor!
    Here's a pic with my autometer gauges that are close to my cool vanilla color! Just need to order the tach now! Drill a hole in the front glass to allow the trip odometer knob to stick thru and the gauge cluster is ready !!
    Thanks again to fleetside66 !!
  11. Here's a picture of one of the two 4 hole panels that are on a local auction. Can see a few of the original gauges and panel orientation.
  12. 1934 Tudor
    chevy57dude, Lil32 and RICH B like this.
  13. fleetside66
    fleetside66
    I'm so happy that the panel met your requirements. I'm stunned the way your gauges fit those holes. I knew the small ones would fit, but didn't realize how at home the big ones would look. It's very unusual for a 1920's gauge panel to have the specs to house modern sized gauges, without a lot of tweaking of the holes. With that one, you couldn't do a lot of alteration without ruining that amazing factory scrollwork (pinstriping?). You seem to have the one panel that lent itself to proper customization without ruining the original intent of the gauge panel. Sweet! I believe the hump was meant to go on the top, but having it on the bottom might even look better. You da man!
  14. Lil32
    Lil32
  15. 64krusty
    64krusty
  16. 2021 tan 32 guage.jpg In my Avatar
    kadillackid, Lil32 and big duece like this.
  17. BDUB77
    BDUB77
  18. 2002p51
    2002p51
    Don't think I've posted any of these photos before. This is the dash on our roadster.
    And this is the gauge cluster I made for the '62 Falcon that we no longer have.
    kadillackid, mad mikey, rc57 and 2 others like this.
  19. 2002p51
    2002p51
    Don't know why those last two pictures don't show up. They are there on my edit screen. Let's try again.
    Falcon gauge cluster:
    kadillackid and Lil32 like this.
  20. 2002p51
    2002p51
    They're here now. I'm confused.
  21. lostone
    lostone
    from kansas
    Bumping up with my WIP dash.
    1938 dash in my 31 Tudor. Pain in the butt, as I didn't use the original dash rail. Built the top and side extensions from scratch.
  22. Bandit Billy
    Bandit Billy
    My 41 PU after getting yet another coat of pink primer this weekend. It is a stock dash that I took liberties with, rounding the bottom all the way across, moved all of the switches, including ignition, to the left side with indicator lights and a raised middle section that will house some non hamb friendly stuff behind a drop down door. Glove box door has a 41 merc clock in it and spring latches in the corners. The upper valance is also block sanded, both are just about ready for some shiny black paint.
  23. jnaki
    jnaki
    Hello,
    This old photo is about as close to the dash of our own 1940 Willys Coupe that we built for the B/Gas Class and then in the 2nd edition a 671 blower on an 292 c.i. SBC for the C/Gas Class. Welded in steel plates to give the frame some rigidity and support. Not bolted in, but welded as per drag racing rules for body modifications as per the tech committee. If the steel plates were bolted in, B/Gas. Since they were welded in strategic locations over the rear axle, C/Gas as it increased the overall weight.
    This Willys dash had most of what we had, including red primer paint on the dash and whole interior bare metal. Our dash had a big chrome Sun Tachometer in front of the driver. A 4 spoke steering wheel and a Moon Foot Pedal without the strap over the toe. In the passenger seat footwell, a Moon Aluminum Gas Tank and Pump was bolted to the floor.
    We kept our dash simple and all of the dash lights worked as the headlights, taillights and brake lights had to work for the rules of a street legal Gas Coupe competition. The firewall was set back the legal 10% distance as per class rules.
    Jnaki
    The last look of our 40 Willys Coupe was in a scrapyard with the whole interior no longer a Red Primer. It was a basic burnt out Black, with White extinguisher spray all over everything. The only thing left was similar to the photo as the steering wheel was all metal with no rubber coating, the tach was melted and gone, while the foot pedal was also missing due to the extreme heat from a gasoline fire. The missing Moon Tank left some bolts through the floorboard. All gauges were now missing from the extreme heat.
    Add all of the missing or melted pieces and add in several chunks of the clutch, flywheel and scattershield embedded into the dash and door sills. It was not a nice way to remember the end…
  24. Rusty Heaps
    Rusty Heaps
    468ACA54-E32C-4E11-A05C-548D082DA27B.jpeg I’ll throw my hat in the ring, 1952 Buick Special coupe. A work in progress.
  25. HOTRODNORSKIE
    HOTRODNORSKIE
  26. Installed our dash Friday and hooked up most of the wires. Now I need to find the new speedometer along with the rest of the little parts.
  27. TCATTC
    TCATTC
  28. Splitbudaba
    Splitbudaba
    6B60D134-55E8-4283-A5BC-E5D8D3770286.jpeg EDCBB084-27F2-4036-A0DF-F04E38833F67.jpeg 619578B6-988D-47F2-9855-BAEC7F609EC3.jpeg 557CDD04-DA61-4052-A5BC-FAC9CE5FF5B0.jpeg FF3F2C12-0C5A-4FE6-AED0-3BFD7717ADAD.jpeg Did my 32’ a few weeks ago. Pulled out my old aircraft sheet metal tools and away I went!
