Lets see some some Slick 60s F100s!
Discussion in 'The Hokey Ass Message Board' started by 65fordguy, Aug 18, 2008.
  1. Pockets
    Pockets
  2. Pockets
    Pockets
  3. 6narow
    6narow
    Super Slammed Rat Slick!
    Love it!
    6narow
  4. BonaDrag
    BonaDrag
    from Seattle
    My '65.
    6narow likes this.
  5. 6narow
    6narow
    Nice!
    All that thing needs are some chrome domes and a little white accenting and she'll be reet for the street baby!
  6. pugs
    pugs
    from Hamburg Pa
    heres a sneak peak of what im working on
    6narow likes this.
  7. 6narow
    6narow
    Don't see many of those!
    Looks like a good starting point. Good luck, man! =)
  8. pugs
    pugs
    from Hamburg Pa
    few more pics
    RMR&C and 6narow like this.
  9. 6narow
    6narow
    Those seats don't look stock, but they do look nice in there.
  10. pugs
    pugs
    from Hamburg Pa
    those are mid 60's GM seats. Im not using them. I just sat them there for the time being as they are posted on CL for sale
  11. 6narow
    6narow
    AHA! I figured something was up! ( ;) )
    No, its a nice looking rig man. Best of luck with the build.
    6narow
  12. pugs
    pugs
    from Hamburg Pa
    thanks 6narrow. Im kind of doing this one in Memory of my older brother that past last March. we had talked about doing up a Slick f100 for about a year, but he also liked the idea of the N series truck
    6narow likes this.
  13. 6narow
    6narow
    We should all aspire to be as honourable a brother as you are.
    RichG likes this.
  14. Busa
    Busa
    image.jpg image.jpg image.jpg Here is mine had it for about a year did a full crown vic frame swap had to narrow it 25 inches and shorten it 12 inches. this bottom pic is the first test fit image.jpg
    droppedstepside likes this.
  15. Busa
    Busa
  16. Busa
    Busa
  17. Busa
    Busa
  18. pugs
    pugs
    from Hamburg Pa
    been tinkering on the truck abit and got a few things done. redid the cab mounts and raised it up an inch and will be up another 1/2 inch when I get new bushings. with the front mounts, once I get the cab off I will close in the sides of the frame bracket and then drill down thu the frame and run a tube down inside for better holding. played with the gauges and put chevy van gauges in the stock ford panel also running a chevy wire harmess as I know its good and very simple. now for the engine I bolted in a 240 inline 6 with the use of a 300ci oil pan and sump and reworking the stock chevy frame brackets to get the motor down as low as possible. thinking about stick trans but since its most just gonna be a cruiser and some light hauling I may go with a C6. I hitting the yard tomorrow to snag a power brake booster off a 66 F350 so I can start working on the brakes and also get a bell housing and starter bolted so I can start checking thing with the wiring to make sure its getting power to it everything
    Busa and 6narow like this.
  19. Busa
    Busa
    Looks good pugs how long you have you been working on it
  20. pugs
    pugs
    from Hamburg Pa
    just really got started on it all but 2 months ago
  21. Busa
    Busa
    I'm hoping the wether breaks so I can start on mine again. Had to move it out of brother in law garage for the winter
  22. pugs
    pugs
    from Hamburg Pa
    this weather does suck but its melting away fairly quick here this week, but he driveway is a total mubby mess right now
  23. pugs
    pugs
    from Hamburg Pa
    been tinkering abit on the truck here and there. picked up a brake booster of a 66 F350, but had to make a new mounting bracket for it. cut up the floor hump and hammered out and welded up some pieces so I have engine clearance, also cut in and made a removable plate to get to the last spark plug with having to remove the whole hump. still need to get the proper master cylinder and proportioning valve and then start on new brake lines. at this point just working on getting everything mocked up and in place before I tear it down for final welding, clean up and abit of paint
  24. Dustan
    Dustan
    from PNW
    My 62 Big back window shortbed
  25. pugs
    pugs
    from Hamburg Pa
    nice truck dustan
    blue57ford likes this.
  26. Dustan
    Dustan
    from PNW
    Thank you.
  27. LM14
    LM14
    from Iowa
    My '62 unibody. Don't think it's on this thread, yet. Has the Industrial Chassis Dakota kit on the front, 4 bar rear, 410" FE wth '61 HiPo heads with bigger 427 exhaust valves and a bit of port work, a factory '63 dual quad intake. Will get the big window cab section put in. Ididit tilt/shift column, Scat bucket seats, moved the custom gas tank to the front of the box. Should be out in the garage working on it right now! Spark
  28. Busa
    Busa
    Like the truck dustan
  29. pugs
    pugs
    from Hamburg Pa
    pulled the truck out to work on the kids blazer and clean up some in the garage, heres a few pics
  30. Crookshanks
    Crookshanks
    Been reassembling after powder coating some nether regions and preserving that OG paint.
