Lets see some some Slick 60s F100s!
Discussion in 'The Hokey Ass Message Board' started by 65fordguy, Aug 18, 2008.
  1. Flying Finn
    Flying Finn
    Thanks guys, I finally got around taking couple of decent pictures, as the old ones were pretty poor.
      493.2 KB
      487.4 KB
    droppedstepside likes this.
  2. sir
    sir
    Try your local boat shop....
  3. TinShed
    TinShed
    I just picked up a 63 F100 last week. I will post up some pictures as soon as I get some H.A.M.B friendly wheels on it. I am in the process of intalling Speedway headers and dual exhaust as I type this. Has anybody installed them on these trucks and had to trim the trans crosmember???? They hit and if I trim about 1/2 inch they will fit, I calles speedway and all the said is they shoutl fit, LOL.
    Tim
  4. 65fordguy
    65fordguy
    sweet rides guys.. keep em coming!
  5. TinShed
    TinShed
    This is the 63 I picked up a couple weeks ago. It is a driving project vs my 57 that has been sitting 20 years. So far I did headers and dual exhaust and rebuilt the 3 speed column shifter. Next is fix the cab mounts and slam it on the ground via a axle flip on both ends. I will probably change the rim color and put the white walls out and some spyder caps are on the way.
    Tim
  6. roosters hot rods
    roosters hot rods
    Great looking truck tim..sounds like your off to a good start..
    Rooster
  7. LL
    LL
    My 64 needs some work. New wheels in the garage waiting for fit test and new tires.
  8. 65fordguy
    65fordguy
    picked up some TT originals in cast finish....265/65 in back... 245/65 in front...[​IMG]
  9. 65fordguy
    65fordguy
    Btt for Sunday crowd..
  10. wreckfixer
    wreckfixer
  11. TinShed
    TinShed
    Got the wheel color changed and spyder caps on and lowered a bit finally.:D
  12. roosters hot rods
    roosters hot rods
    Great job tim..it looks sweet !..how did you lower it >? springs or flip ?
    Rooster
  13. Jeffstamps
    Jeffstamps
    from Fresno
    How do I join thr 61-66 Ford F100 Alliance. ? I would love to join!
  14. Look it up under the community tab up top. Search for the group name and click join.
  15. crazy wheel
    crazy wheel
    from Missouri
    I found this one last weekend, custom cab, camper special, my youngest son (18yr old) ended up buying it. it is a '65
    He has a mile wide smile when driving it.
    Here is mine, it is a '66
  16. Shawn F.
    Shawn F.
    For those of your running wide white walls, what are the specs on them with your stock F100 wheels? I am in great need of new tires for my 66 and plan to run WWW tires on the stock rims but not sure what is the widest I can run and which bias ply one to go with. Any info here?
    Also are you guys running 3 1/4" wide whites or what?
    Thanks in advance! Keep the pictures coming!
  17. Randzz75
    Randzz75
    Heres my 1966 f100, lays frame on stock 66 wheels
    And here's before primer
  18. Chris F100
    Chris F100
    62 F100 Flareside (stepside)
    Just dropped in the motor this morning
    Have a full Clifford set up to go on it.....
  19. TinShed
    TinShed
    Have any more of what you did to the suspension?
  20. Shawn F.
    Shawn F.
    Also whats your tire specs as far as width, height, white wall size, etc? I am looking for that exact look with the stock wheels minus laying frame...
    Thanks!
  21. Randzz75
    Randzz75
    I four linked the rear and and clipped the front with a 79 firebird also shaved about an inch out of the belly of the frame and boxed it all in, heres the rear, ill try to get some pics of what i did to the front
    and heres one of the front
  22. Randzz75
    Randzz75
    tires are 205 70 15's radials from big o, white walls are, believe it or not, port o walls, but if i had to do it over again id probably go with real firestones
  23. Randzz75
    Randzz75
    I also would love some opinions on what to do to get a useable bed back, like raised bedfloor or any other ideas, Dont worry if its not your cup of tea , I dont get offended easily
  24. I haven't seen this thread yet, I guess I can add to it.
  25. My buddy, Tom's 60....volare' front, 9 inch rear, 383 mopar/pushbutton torqueflite...he's made a helluva price to me.
  26. You want to break it to him? ^^^ that's a "Fridge" not a "Slick" ^^^
    :eek::rolleyes::D
  27. daddio211
    daddio211
    The thread DOES say "Slick 60s F100s", so if it's a 1960 I think it qualifies... :D
  28. Used Up Junk
    Used Up Junk
    from Merced, CA
    The term "slick" refers to a specific body style not a year. I'm sure you are just busting the guys balls though! It is a nice truck though.
  29. daddio211
    daddio211
    Yep, I'm just messin' with Timmy... :D
  30. TexasDart
    TexasDart
    Randzz...to get a 'useable' bed...probably put a bed in there..ie...raised bed, then maybe get you some sideboards that can be put into the stake pockets...kind of like a flat bed truck.
