Let's Build a 265 Chevy V8!!!!!
Discussion in 'The Hokey Ass Message Board' started by JeffreyJames, Nov 9, 2009.
  1. HEATHEN
    HEATHEN
    from SIDNEY, NY
    Only the factory dual points were all centrifugal advance; the single point distributors had both centrifugal weights and a vacuum pod that necessitated a rectangular slot in the side of the housing. If you're not concerned about date codes, the '57-'61 style dual point distributors are neither rare nor expensive. They were so popular to purchase over the parts counter by hot rodders for their projects that, although 1961 was the last year Chevrolet used them in production, I've seen them with date codes as new as 1966.
  2. falcongeorge
    falcongeorge
    from BC
    Thanks Heathen. And that about sums up why I want one for this deal.:D
  3. GMC BUBBA
    GMC BUBBA
    I have a basket full of cast iron cores just let me know what you need and which engine . Early 265s used a distributor with flat space ( for oil control) , i believe 55-56 .
    A built cast unit is $100 without cap and $150 with cap and rotor. They have the look for sure........
  4. HEATHEN
    HEATHEN
    from SIDNEY, NY
    Right, '55-'56 engines used the housing with the flat. For this reason, '56 dual points had different I.D. numbers---1110872 and 1110879, as opposed to 1110891 for the '57 and up engines.
  5. falcongeorge
    falcongeorge
    from BC
    I have a 283. I'll be in touch when the time comes, that seems very reasonable.
  6. mart3406
    mart3406
    from Canada
    'Double-ditto' on that. Even though
    the stock 265's and 283's only used
    a hub instead of a damper, adding
    one from a later 327 or 350 would
    *definitely* be a good addition and
    cheap insurance of a smoother,
    longer-lasting engine. One small
    caution though - with the Hurst
    front "cradle mount", you'll need
    to use a standard 'small-diameter'
    crank damper from a standard,
    "lo-po" 305, 327 or 350, as the
    bigger, better, 7 or 8 inch-diameter
    dampers used on the "hi-po" 327's
    and 350's are too big to clear the
    Hurst mount.
    Mart3406
  7. It's no biggie - I drilled my 283 crank in the car and tapped it. Had to go with a 1/2 inch bolt to get good purchase on the threads.
  8. Gretschplayer
    Gretschplayer
    One more thing: 265's and early 283's used a "rope" rear main seal. Modern replacement rope seals are made using different, more eco-friendly & non toxic material, and don't seal very well. Several companies make a 'drop in', no machine work required, modern style lip seal for these engines that are the better way to go.
  9. TexasSpeed
    TexasSpeed
    from Texas
    Couple interesting pages from the 1965 Hot Rod Yearbook on early Chevy V8 head differences.
    1Nimrod likes this.
  10. mart3406
    mart3406
    from Canada
    I don't know where you'd find one,
    because they haven't been made
    for years either, but if you want to
    instal dual points in a standard
    early-style Chev distributor, "back
    in the day
    " and right through into
    at least the mid-70's , several
    different aftermarket companies
    - ie - notably, 'Cal Custom', 'Segal',
    'Mallory' - and probably a bunch of
    others too - also made very
    inexpensive dual-point conversion
    kits for these distributors. You might
    luck out and find one of these
    aftermarket conversion kits, NOS,
    at a swap meet or on "that internet
    auction site that starts with a E
    ":D.
    Personally, if it were mine though
    - since no-one is going to see what's
    under your distributor cap, for ease
    of maintenance, I'd do away with
    the points altogether and add a
    either a Pertronix or an HEI
    electronic conversion to your
    early-style distributor housing and
    be done with it. But if you really
    want and insist on dual points,
    some of those old aftermarket
    conversion kits are still out there
    and if you find one, probably for
    cheaper than the original GM
    stuff.
    Mart3406
  11. falcongeorge
    falcongeorge
    from BC
    Thanks for the tip on the period aftermarket conversions. As far as the petronics stuff, it'll be a cold day in hell before you see me using that stuff on a period build. If I was going to do that, I'd just build a 377 and grind the side mounts off the block, and add some epoxy triangles to the ends of the heads.
    I grew up with points, so first off, I dont buy all the new age, voodoo bullshit about how unreliable they are, been there, done that, got the t-shirt. Even when I DO run an MSD, I still trigger it with points, way better system IMO. If the box goes weird on me, I switch a couple wires, and I am back to points and coil. Never happens, right? Bullshit. It has happened to me at the track, and if I was using a system without points I would have been done for the day, and paying for a tow-truck home. Instead I went two more rounds.
    According to both Heathen and Bubba, getting a cast iron dual point is not a big issue (see posts 366 and 364) so thats the route I will be going.
  12. cabriolethiboy
    cabriolethiboy
    Just read all 19 pages. I am putting a 57 283 (220 hp, powerpack) in my 32 Vicky and I may have missed it about the starter situation. What starter do I use with an adapter hooked to a 39 trans?
    Also how about using a hydraulic cam with Rhodes lifters? What grind would give an 097 sound? I have a Crower stock lift circle track cam ( 327-350 spec) too much? I am not familiar with them, I bought it at an auction for $2.00(new in box) I still never caught what an 098 cam was?
  13. c57heaven
    c57heaven
  14. falcongeorge
    falcongeorge
    from BC
    If you want it to sound like a 283 with an 097 Duntov, the best way to do that is to put an 097 Duntov in it, dont you think? They are still available.
  15. mart3406
    mart3406
    from Canada
    Yep. If that's what you want, then
    just get a '30-30 Duntov - 097"
    cam - either an original Chevy unit
    or one of the aftermarket re-pops.
    Another good one too, if - (sacrilege
    of sacrileges!!:eek::D) - you want juice
    lifters instead, would be the old
    Chevy 350hp/327 cam, GM part
    number 3863151 - again, either
    the original Chevy piece or one of
    the numerous aftermarket re-pops
    of it.
    Mart3406
  16. falcongeorge
    falcongeorge
    from BC
    The 30/30 and 097 are not the same cam. I would never recommend someone put a 30/30 in a 283. The last three numbers of the 30 across p/n are 346 the 097 has about 20 degrees less duration @ .050.
  17. mart3406
    mart3406
    from Canada
    My bad!:eek::eek: You're right about the
    "30-30" and "097" not being the
    same cam. The "30-30" Duntov
    cam was the 375hp/327 'fuelie'
    cam - and also later used in the
    302 Z/28 as well. Back in the early
    '70's I used a '30-30' cam in a
    283 in my daily-driver '64 Chevelle
    and with the stock-compression
    283, unless and until you had the
    revs up above 3500 rpm or so, it
    was quite a bit too much cam.
  18. falcongeorge
    falcongeorge
    from BC
    Yuppers.
  19. HEATHEN
    HEATHEN
    from SIDNEY, NY
    An 098 cam IS an 097 cam. As was the case on many General Motors parts, the casting number on the part was one digit off from the actual part number that showed up in the catalog.
  20. HEATHEN
    HEATHEN
    from SIDNEY, NY
    Yeah, many years ago, my brother insisted on putting a 30-30 in his 283. I think that I could have beaten him from 0-30 on my ten speed bike.
  21. mart3406
    mart3406
    from Canada
    Yeah..but once you got the revs
    up...:D I had an old factory tach
    out of mid-60's Buick that only
    read to 6000 rpm in my '64
    Chevelle and at the drags, once
    the car got rolling, I'd run the tach
    off the end of the scale and then
    count to three and shift! Getting
    the car off the line though was
    quite an exercise involving a lot
    clutch slipping and/or wheelspin
    to get and keep the revs up until
    the car got rolling! The ET's were
    nothing to write home about, but
    for a 9 to 1 compression 283 in a
    3400 lb car it'd really mph though!
    Mart3406
  22. falcongeorge
    falcongeorge
    from BC
    how much are the dual wcfb dogbone intakes usually going for now? Major goldchainer $$?
  23. Roy's ride
    Roy's ride
    from Michigan
    I wish I found this thread when I had my 57 265 done a few years ago. After living with this motor a few years I've become a big fan. Nice small package for Hotrod applications and makes all the proper sounds. I would do another.
    I tried to keep as period 57 as I could...
    57 power pack heads
    57 valve Corvette covers (low script)
    56-57 Nicson 2x2 intake
    Nicson flame arrestors
    early Rochesters
    Kept the canister oil filter etc..
    1Nimrod likes this.
  24. HEATHEN
    HEATHEN
    from SIDNEY, NY
    The bare intakes aren't so bad (as in the $200 range most of the time). The correct carbs are a different story, especially the front carb with no choke.
  25. joel
    joel
    Looks like '62 or maybe '63 corvette 6 qt pan from your pic and description.
  26. squirrel
    You should be able to use the common Offy adapter that has the three starter bolt holes, this will work with a 55-57 block that is not drilled for the starter. The TurboGlide began in 57, and it used a bolt on starter, so you may have the holes in the block already? but the 3 bolt starter (used on trucks with manual trans thru 72) is the old fashioned way to go.
    http://www.speedwaymotors.com/Chevy-Engine-to-Early-Ford-Transmission-Adapter-Kit,1157.html
    if you can't find a nice old one
  27. JeffreyJames
    JeffreyJames
    from SUGAR CITY
    Man I loved looking at your engine a couple years ago at the Autorama. The Nicson 2x2 intake is just down right righteous.
    Yup, I'm running that exact combo with a vintage Offy adapter, the original '56 Block, '56 Chevy starter and a 167 tooth flywheel and mated to a '39 Ford Trans.
  28. falcongeorge
    falcongeorge
    from BC
    $200 is easily managable. I wouldn't be adverse to reworking/re-calibrating non-original WCFB's. I have been rounding up Rochester 2gc's for the trips, but the dogbone intake and WCFB's is what I would REALLY want, I just figured it was going to be BIG money.
  29. A recent acquisition...
    Sent from my Droid using TJJ sucka!
  30. JeffreyJames
    JeffreyJames
    from SUGAR CITY
