Let see some chain driven blowers!
Discussion in 'The Hokey Ass Message Board' started by Flatred53, Jan 22, 2011.
  1. Ok I know it’s not the best way to go, but its looks cool.
    Lars
  2. fearnoevo
    fearnoevo
    from Iowa
    A peg leg and eye patch are cool too, but I wouldn't want them.
    Chains require lube. Exposed chains sling the lube they require. Look at that cowl, its soaked in some sort of oil. Traditional + ridiculous = Ignorance.
    As if its not bad enough having an exposed saw blade in the form of an open fan, lets add a chainsaw to it too.
    GREAT IDEA LEFTY!! LETS DO IT!!!11
    Lend me your good hand for a second.....
  3. As I said not the best way to go,, just wonder if there was some picks of others. Sorry but I just like the stance,,
    Lars
  4. BHT8BALL
    BHT8BALL
    You didn't say you wanted to see the chain, but this worked and was quiet and no oil on the firewall. Pat
  5. 31modelo
    31modelo
    Here's a SBC/Cragar setup I once owned (not on in this pic), wish I could of found the Howard's chain drive cover.
  6. stude_trucks
    stude_trucks
  7. Lotek_Racing
    Lotek_Racing
    If you're looking to do it, most drive chain has a max speed rating in feet-per-minute. Easy enough to calculate and find a safe one.
    I don't think I'd be comfortable with that much chain screaming around at 5000 rpm. The whip in it must be amazing.
    Shawn
  8.
  9. borntoolate
    borntoolate
  10. pugh433
    pugh433
    from toledo
    If thats lube on the cowl from the chain, then judging by the pics there must have been some act of god to somehow miss the rad hose and the blower that are 6" from the chain. Prob. a float hung on a carb. I use a chain lube that dries quickly like a wax and wont fling off. Any how, more pics..
  11. straightaxlenova
    straightaxlenova
    Me likey!!
  12. I wouldn't be all that scared of that.. after all there's one right behind the timing cover.. they go 300k+ miles.. without breaking.. maybe stretch out and eat a hole in something though. I can see running a chain drive for a blower.. especially if its a blower motor that's packed into an engine bay and doesn't have enough room to run a 3" wide belt....
  13. Warpspeed
    Warpspeed
    It should work.
    After all, many engines still have timing chains that see hundreds of thousands of miles.
    In fact, some of the DOHC Japanese engines are going back to timing chains, because they last longer than timing belts. I believe the overhead cam Ford 427 had a twelve foot long timing chain.
    I much prefer multirb or toothed rubber belts for my blowers.
    But if space is at a premium, you could make a fancy timing cover extension to house the blower drive chain.
    It would keep the chain clean and splash lubricate it from the front of the sump. It could also be the oil return from the blower drive gears. Never tried it, but it should be quite practical to do.
  14. burnout2614
    burnout2614
    N A S T Y !!!!!!!!!!! I like it. peace
  15. 303racer
    303racer
  16. Warpspeed
    Warpspeed
    Anyone tried a gear drive ?
  17. I have seen a few pretty old pictures of them, but they still look pretty rat roddy to me.
  18. Mattbee
    Mattbee
    Do you have anymore pictures of this one?
  19. badass. But I like 3 v-belts better.
  20. ftroop
    ftroop
    from Detroit
    Hollish Olds
  21. borntoolate
    borntoolate
  22. Thanks for the response, lot of cool setups.
    I’m planning to put a blower on a 59ab, I wanted to go for the v-belt but think I can save some space with chain. I have to make a mock up and check, don’t want an eclectic fan (AV8).
    Lars
  23. ChassisResearchKid
    ChassisResearchKid
    from Michigan
  24. Dreddybear
    Dreddybear
    Thats WICKED.
  25. oldebob
    oldebob
    from Spokane WA
    Heres one made from a B52 bomber starter motor. Never had problems with the chain.
  26. How about a picture of a SBC Howard chain drive enclosure cover?
    They make awesome wall hangings:)
    Dennis
  27. MrGasser
    MrGasser
    from DETROIT
    4-71 blown 283 c.i. Chevy...
  28. Pretty cool stuff
