Technical Left my Holley in the carb dip a little long,is it ruined?
Discussion in 'The Hokey Ass Message Board' started by 327Eric, Jan 30, 2016.
  1. 327Eric
    327Eric
    A couple years ago I was working on an old Ford,and pulled apart an 1850 holley, and put it in the Chem dip. And forgot about it for about 1-3 months. So I pulled it out, cleaned it off and put it in a box. Now I need one. Is this one worth rebuilding, or will it be too porous to seal and work . any thoughts or comments. I have more, so its not a big deal, just cleaner than the rest.
  2. falcongeorge
    falcongeorge
    from BC
    I've never done that before, so I don't know for sure, but I would think it should be fine. Is there visible etching/corrosion on the gasket surfaces or anything?
  3. moonman29
    moonman29
    Yes I would say it's ruined. I did that to one of my carbs but my was partially submerged and you can tell the difference between the two areas.
  4. gimpyshotrods
    gimpyshotrods
    No doubt. Ruined.
  5. chargin03
    chargin03
    I would think so
  6. partsdawg
    partsdawg
    from Minnesota
  7. BuckeyeBuicks
    BuckeyeBuicks
    from ohio
    Hang it on the wall as a reminder to not do it again, its history.
  8. mrspeedyt
    mrspeedyt
    you can reassemble it. if it works... great! if it doesn't.... wall art!!!
  9. '51 Norm
    '51 Norm
    from colorado
    I don't know what is in chem dip these days but in high school auto shop in 1973 one of the students left a carburetor in the dip over Christmas break. When he pulled it out all that was left were the steel and brass parts. It was most impressive.
  10. 327Eric
    327Eric
    It does have visible pitting. Not totally dissolved. dip was old. I may play with it just to see, but won't count on it.
  11. well....count me in as forget full....mine stayed in about 4 days or so...came out a little grayer...cleaned it up and wondered if I should build it....what you guys think ?
  12. henryj1951
    henryj1951
    from USA
    well try it... go for it... build it...
    -n- let us know
    i left a piece of aluminum in once for 30 days and it turned it to mush...:cool:
  13. falcongeorge
    falcongeorge
    from BC
    if its pitted, its f*cked.
