I was surprised to learn Pontiac used LH studs, at least on Tempests, in 1961. http://pontiac.oldcarmanualproject....t Shop Manual/04-Wheels and Tires/image1.html
Would that have been on the driver side studs only? Studs marked "L"? This had to cause some real headscratching and choice words over the years. There is an old MOPAR video that explains the reasoning, and it does work, sort of. Not that there was a plague of loose tires flying off. But, it has happened. http://www.moparmax.com/columns/magnante/v_5-1.html
Do you all mean "studs" or lug bolts? The "left hand stud" brings some really weird images to mind. LOL
I think that nearly every manufacturer tried them at one time or another. it was fair logic but as we have proven over the years it was totally not necessary.
Oh wow, after many years of absence from Mopars I bought a really nice Dodge and put her up on the lift to change the tires and redo the brakes. I got the Ingersoll out and promptly broke a left side lug off. I decided that it was probably over torqued and tried another which also broke! I then remembered about the lefties on the left side and successfully removed the rest. I went to the right side and broke another (you got to reverse the wrench dummy). This issue is all about the fact that some mechanics could get distracted and leave the lugs finger tight and subsequently the car was driven and the left side wheels would loosen to the point of departure! Millions of autos are made and used with all righty tighty now with no adverse effects. I changed my Dodge to all righties.
