Technical LED turn signal flasher
Discussion in 'The Hokey Ass Message Board' started by Pat Thompson, Mar 24, 2019.
  1. Pat Thompson
    Pat Thompson
    If you are going to run LED turn signals and are having trouble finding a flasher that will work, I found a Grote brand part #44891 grounded flasher will do the job. After grounding, I did have to figure out which side of the flasher took which wire as the current has to flo a specific direction.
  2. pitman
    pitman
    Hmmm...as in Uphill+, or down - ?
    In switching over to LED home lighting, the current is ~ 1/10th of the incandescent.
    On a vehicle, you may need
    All lights = LED, to have consistent flash.
