Technical Leaking valve
Discussion in 'The Hokey Ass Message Board' started by dtwbcs, Jul 15, 2018.
  1. dtwbcs
    dtwbcs
    from Brenham,TX
    Brake line residual valve is leaking.1960 Bel Air ; disc/drum, dual master cylinder. Is there a way to seal the threads?On that one end there is not a flare fitting.I have a new residual valve that I will install proportioning valve.JPG proportioning valve.JPG valve end.JPG brassfitting.JPG insert.JPG
  2. saltflats
    saltflats
    from Missouri
    Are you using a pipe to flare fitting?
  3. dtwbcs
    dtwbcs
    from Brenham,TX
    Yes but it leaked. I want to know what to do, to prevent a leak , before I install the new part
  4. squirrel
    depends where it's leaking from. Make sure the threads are all the type that you think they are. If the flare on the tube is defective, it will leak. You would need to cut off the end, and make a new double flare.
    dtwbcs likes this.
  5. dtwbcs
    dtwbcs
    from Brenham,TX
    Installed new line from mc to the new residual valve.Tightened everything before installed in the car.No leak.Tomorrow I will bleed the rear line and drive the car;to see how the brakes are.
    Thanks as usual:)
  6. dtwbcs
    dtwbcs
    from Brenham,TX
    residual valve leaked- new outta box.took it out of the system.A buddy stated I need a proportioning valve; so i ordered one.
  7. KJSR
    KJSR
    from Utah
    1. Utah HAMBers
    Are you using tape on flare fittings??
