Hot Rods Lay back 1934 Ford Roadster Windshield
Discussion in 'The Hokey Ass Message Board' started by gypsy, Feb 27, 2024.
  1. gypsy
    gypsy
    from florida
    Can and how can I lay the windshield stanchions on a 1934 Ford roadster back? Thanks
  2. alchemy
    alchemy
    Cut and weld?
  3. gypsy
    gypsy
    from florida
    Thanks, I believe that there's a way to do this without cutting and welding, I saw one that was cut and welded and it didn't flow smoothly. Sort of had a kink in it.
  4. Rickybop
    Rickybop
    No experience with this.
    So, an honest question.
    In stock configuration, the curve of the bottom of the windshield perfectly matches the curve of the top of the cowl. With a rubber strip between as a seal.
    So I ask, how do you deal with the mismatch of the two curves once the windshield is laid back? A custom shaped rubber seal?
