Technical late s10 1994/5 electornic speedo drive to mechanical cable
Discussion in 'Traditional Hot Rods' started by nobby, Sep 19, 2019.
  1. nobby
    nobby
    do I simply remove the tone ring from the gm out-put shaft and swap it with a speedo drive gear
    then fit a th 350 drive housing with gear
    connect to my speedo
    is the divot on the shaft and the metal clip that holds the tone ring the same as a mechanical drive
    thanks
    where to buy the parts??
    4.11's 235 55 15 tire
    what colors please
    or 4.11's 235 55 15 what colour gears please
    can you still get the bits
    thanks
    I am NOT fitting a gm tail to a FORD output shaft with the divot in a different place
  2. @KatoKings knows a lot about the t5.
    Ronny
  3. RMR&C
    RMR&C
    from NW Montana
  4. irishsteve
    irishsteve
    There was a guy selling the conversion service on Ebay.You sent him your parts,and he did the machine work.May still advertise the service.
  5. alchemy
    alchemy
    No it's not simple. The electric housing's hole is at the wrong angle and location. KatoKings welds in a new boss and machines the proper hole for the mechanical sender. He also sells the drive parts needed to complete the conversion.
  6. 911 steve
    911 steve
    from nebraska
    a lot simpler option if you're interested..I bought a gps speedo sender from speedway for about $140-150. simple 3-wire hookup & works great...only drawback it takes 6 blocks or so to acquire a signal after being in garage.
    eicke likes this.
  7. Kiwi 4d
    Kiwi 4d
