Hot Rods Lake headers or ram horns
Discussion in 'The Hokey Ass Message Board' started by haileyp1014, Aug 13, 2018.
  1. Lake headers
    53.8%
  2. Ram horns
    46.2%
  1. haileyp1014
    haileyp1014
    from so cal
    Hey guys I've been working on my model a For a while. Any input on lake headers or ram horns? Motor is just for mock up. Will run tri power, 32 shell and keep white walls. Still need to install subrails and mount body. Just thinking ahead. 20180722_154709.jpg 20180728_183757.jpg
    goldmountain likes this.
  2. cretin
    cretin
    Where would you route the rest of the exhaust if you used the rams horns?
  3. BoilermakerDave
    BoilermakerDave
    from Las Vegas
    Ram horns are cool. But man, a fenderless model A? Lakes for sure.
  4. 3banjos
    3banjos
    from NZ
    Original ram horns do look good, but not if your after better performance outa your motor. Throw it on a dyno
    and you'll see the surprising difference. Coupe looks good so far.
  5. 392
    392
    Lake headers are cool but I’d route them back. If open very loud and ear plugs optional. Lots of pros and cons.
  6. rusty rocket
    rusty rocket
    I have the speedway rams horns on my 32 and Lakes on my T modified. I like them both. If you are going to run a hood I would say rams if open Lakes.
  7. MMM1693
    MMM1693
    I agree with rusty rocket. On my sedan I took a pair of center dumps, ground off casting marks, lumps and bumps and had them coated. It worked out pretty well. On my coupe I run hoodless and have the pipes. Besides hoods belong in jail. Call Matt at Gear Drive for Lakes.
  8. missysdad1
    missysdad1
    It depends on the overall theme of the car. If you are going for a "road" version of a fenderless highboy then the ram horn manifolds will look and work best. On a 'bad boy" coupe the headers will look better. Finalize your theme, then pick the exhaust to match.
    MMM1693 likes this.
  9. goldmountain
    goldmountain
    Run the ram horns and doing tuneup will be a lot cooler on your body - and I Don't mean the car body.
    Sent from my SM-T350 using The H.A.M.B. mobile app
    haileyp1014 likes this.
  10. Blues4U
    Blues4U
    from So Cal
    Baffles in mine make them very tolerable, and sound great. Cheep too!
  11. Barn Hunter
    Barn Hunter
    Lakes look a lot more hotrod.
  12. In my mind small block powered hot rods should have rams horns or long tube headers. Granted I am not the same as everyone else and in my mind has nothing to do with what anyone should do.
    haileyp1014 and Blues4U like this.
