Lacing metal
Discussion in 'The Hokey Ass Message Board' started by 54pathfinder, Dec 1, 2013.
  1. 54pathfinder
    54pathfinder
    from canada
    Did you know you can slip roll lace into 1100 series aluminum with a slip roller? I do that sometimes. Anybody ever done that? It's pretty
  2. xpletiv
    xpletiv
    from chiburbs
    Pictures, we need pictures...
  3. 1955IHC
    1955IHC
    Yes pictures please.:)
    Sent via Illinois Bell Telephone Company's Car Radiotelephone
  4. 54pathfinder
    54pathfinder
    from canada
    Ok, I found some lacy stuff in the rag bin at work. I'll try it again tomorow. I'll take pics
  5. xpletiv
    xpletiv
    from chiburbs
  6. gimpyshotrods
    gimpyshotrods
    I can see that looking good. Put a ton of clear on it, until you can sand it out smooth.
  7. 54pathfinder
    54pathfinder
    from canada
    If I can get it deeper this time I might be able to spray paint the panel and then sand off the high points to bare metal and then clear coat.
    Hood Birds c.c.
  8. gimpyshotrods
    gimpyshotrods
    Push it! See where this can go!
  9. metal man
    metal man
    I guess if that works, you could do small parts in a press. Interesting. Show us!
  10. 80WTI
    80WTI
    Subscribed and interested on the results. Thanks, Lee
  11. xpletiv
    xpletiv
    from chiburbs
    He will get to them as requested earlier.
  12. Crusty Nut
    Crusty Nut
  13. 54pathfinder
    54pathfinder
    from canada
    I tried some today but the lace was too squishy. I need the crusty stuff. Ill post pics as soon as I have something good
    Hood Birds c.c.
  14. Gotta see this
  15. subscripted I have a 42inch Niagara slip roll I can't wait to try this!
  16. 54pathfinder
    54pathfinder
    from canada
    I have to get some good lace, it has to be starched up good and then you can experiment with different approaches. The one time I did it was at work with some stuff off the bottom of a rag shirt. The last time didn't work because the lace was too squishy. Basically lots of pressure and a thin one ply cardboard under the metal so there's room for the metal to imprint. I'm going to keep at it, just have to finish barfing! I got the stomach flu from the kids. Yeesh! Let's all give it a a go with various equipment. Post pics if you try it.
    Hood Birds c.c.
  17. 54pathfinder
    54pathfinder
    from canada
    In the meantime here is a bit of my aluminum work. I stripe at the shows during the summer. This is all aircraft aluminum. ImageUploadedByH.A.M.B.1386138594.333053.jpg ImageUploadedByH.A.M.B.1386138616.760262.jpg
    Hood Birds c.c.
  18. Possibly spray paint it to add density?
  19. wsdad
    wsdad
    Please explain to those of us who have never heard of this.
    What is a slip roll or slip rolling?
    What is lace? Are you talking about that stuff on the fringes of women's clothing?
  20. xpletiv
    xpletiv
    from chiburbs
    How about some pics of the not-so-good turnouts so we can get an idea?
    Tease.
  21. wsdad
    wsdad
    Found this:
    A slip roller rolls sheet metal to form items like stove pipe. If a taper is needed then the material can be "slipped" to form it.
  22. Stu D Baker
    Stu D Baker
    from Illinois
    I believe the OP is putting lace fabric behind thin aluminum sheet and then running it under pressure through a slip roll to transfer the lace design into the aluminum. Stu
  23. 54pathfinder
    54pathfinder
    from canada
    That's a good idea!
  24. 54pathfinder
    54pathfinder
    from canada
    Yeah sorry guys, a slip roller is exactly like in the picture above. Only you don't have to curve it with the back roller, you just leave it down and set the front grabbing pair really really tight and then pull your stack up of commercial grade or 1100 series aluminum and lace like found on women's lingerie or grannies tablecloth right through and see what you got. I want to perfect this little trick so I can use it on my 54.
  25. Pics, we need pics!! :D
  26. I don't believe it til I see it!
    A thread like this shouldn't even be started without pictures! :D
  27. niceguyede
    niceguyede
    from dallas
    Tape your lace to a piece of metal and hit it with a couple coats of spray paint. When it dries it will be nice and crunchy stiff. I'm excited to see this Shit man
  28. 80WTI
    80WTI
    ^^^^ It's working for me
  29. Might get too squishy!
